Old version problem. The beta key does not work (?)
balthazar70
Post by balthazar70 »
Hi guys, I haven't been able to use MakeMKV for a few days now. Same problem that others have encountered with the old version.
I tried using the key found on a specific page of the website (I think it's the beta key? https://www.makemkv.com/buy/)
But the code tells me it's invalid. Does anyone have a working key?
Re: Old version problem. The beta key does not work (?)
Post by d00zah »
balthazar70 wrote:
Sat Aug 23, 2025 2:54 pm
Latest beta key can always be found here... MakeMKV is free while in beta
Did you obtain the beta key posted at MakeMKV is free while in beta?
If not, then you do not have a current beta key.
Using the "buy" link, you should have received a permanent key. The delay in getting those went away about a week ago.
balthazar70
Thank you all. The key now works.
Evidently, the key suggested on the page I mentioned is not the correct one.
Thank you again!
