PowerDVD won't integrate with MakeMKV for direct playback of UHDs, presumably because it is designed to play UHDs the "official" way (and that only works up to v22 or early v23). I have to use MakeMKV and XReveal together to be able to use it. When AnyDVD was still around you could use that instead of XReveal.-Jim- wrote: ↑Fri Aug 22, 2025 2:40 pmI have half an answer for you.Cyberlink PowerDVD 24 Ultra.
Why half an answer? Because I've only tried it on regular Blurays and not yet on UHD.![]()
I've been using PowerDVd for well over two decades and I'm a fan. I think it originally came with a work Laptop ages ago. I have my main Box integrated into a 5.1 system via HDMI and like having the ability to easily use Menus, select Audio streams, etc. I'm pretty sure they have a demo version you can pull down to try.
https://www.cyberlink.com/products/powe ... en_US.html
I have ordered an Asus BW-16D1HT Blu-Ray Burner which is due here on Monday. Once I Crossflash it (Thanks to MartyMcNuts), I'll give playing UHD Disks a try.
Good luck with your pursuit.
