Crossflash for Verbatim BU40N 1.05
IronVortex
#1 Post by IronVortex » Fri Apr 04, 2025 12:15 pm
Hello, can I downgrade the firmware on my exact drive I bought in 2025? :D
TL;DR
I bought a Verbatim HL-DT-ST BD-RE BU40N UHD Blu-ray drive (USB-C, 4K) but it can’t play UHD videos or rip UHD discs. It works for CDs but isn’t LibreDrive-compatible. Can I downgrade the firmware to fix this? I’m stuck with it and unsure about returns.
From what I gathered the full name + product marketing is as followed: "Verbatim HL-DT-ST BD-RE BU40N 1.05 MO2P2FG5225" (Ultra HD 4K External Slimline Blu-Ray Writer USB 3.2 Gen 1 with USB-C Connection) and this is my first brand new UHD drive I bought a week ago arrived yesterday and I plugged it in my desktop PC with its USB-C adapter. And it works great at ripping CDs with EAC but can't play the videos or music directly through File Explorer or even VLC (media player) nor is it directly compatible with LibreDrive (as MakeMKV reports in failure and in specs) but MakeMKV recognizes it (anyway as a drive). I mainly bought it cause an AI conversation I had told me it would be compatible. That was my first mistake. And my second was ever doubting youtube videos or forum posts. But maybe that's just me being lazy and eager to rip UHD.... I didn't get any forums just skimmed through Reddit a bit, and so I might've been misinformed by AI massively. It was really stupid on my part! I mainly bought it cause it had USB-C and a excellent price for me, and would've been compatible for UHD, Blu-ray, DVD, CD playing but ripping for UHD is out of the picture?... no but literally?
I haven't seen many or any top posts regarding 'Verbatim' UHD drives, but was mentioned I bet. And really I don't have the means to buy a diff drive and so I'm stuck with this prob. I hope I can flash it (I have no idea what crossflash is) but I am inexperienced so in dire need for technical support. I am unsure if I can return the drive as I didn't buy it from Amazon so... (the refund policy is probably already broke!) I'm pretty much stuck with a useless drive, right?
So my drive is: Verbatim 43888 (LG BU40N)?
Below I will attach any details and update information about the drive if its needed!
I am unsure the date it was made (ISNT LISTENED ON PRODUCT BOX). and i havent done anything to it. it was brand new when i unboxed it. tried to rip a uhd movie with it with MakeMKV but it said: "LibreDrive compatible drive is required to open this disc - video can't be decrypted."
Product: BD-RE BU40N
Revision: 1.05
zittrig
Re: Crossflash for Verbatim BU40N 1.05
#2 Post by zittrig » Fri Apr 04, 2025 12:51 pm
Flash directly to 1.03MK.
Tool and firmware packages you can find there ------> viewtopic.php?f=16&t=22896
IronVortex
#3 Post by IronVortex » Fri Apr 04, 2025 1:03 pm
nvm to complicated to flash dont want to risk for brick and ill just look at free automated alternatives if possible
Palpex
#4 Post by Palpex » Fri Aug 22, 2025 12:32 pm
zittrig wrote: Fri Apr 04, 2025 12:51 pm Flash directly to 1.03MK.
Hi, ive got the exact same device, tried flashing both to version 1.03/4 MK but i always get the error: "Command produced error code 0xff056103"
Is this a know issue?
#5 Post by Coopervid » Fri Aug 22, 2025 2:56 pm
Palpex wrote: Fri Aug 22, 2025 12:32 pm
Are you using SDFTool flasher or a command line? Windows or other OS? Post your Makemkv info or copy&paste the error message.
#6 Post by MartyMcNuts » Sat Aug 23, 2025 12:14 am
Ensure there is no disc in the drive.
tomcat1511
#7 Post by tomcat1511 » Sat Aug 23, 2025 12:01 pm
Hi there,
this is my drive according to MakeMKV information:
HL-DT-ST BD-RE BP55EB40
I flashed to this firmware:
HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.bin
The drive playbacks the Bluray Superman - The Movie (2000) with 1080p in VLC media player without problems.
Inserting the Ultra HD-Bluray "Alien Covenant" (2017) though, MakeMKV doesn't recoginze the disc ("no disc inserted") and the drive spins down after a while.
What am I missing/ doing wrong?
DavoBR
#8 Post by DavoBR » Sat Aug 23, 2025 1:28 pm
Maybe post your MakeMKV information
tomcat1511
#9 Post by tomcat1511 » Sat Aug 23, 2025 1:39 pm
My MakeMKV info section looks like this:
Laufwerksinformation
OS-Gerätename: H:
Produzent: HL-DT-ST
Produkt: BD-RE BP55EB40
Revision: 1.03
Serienummer:
Firmware-Datum: 2120-05-07 09:24
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 19
Firmware version: 1.03
Keine Disk eingelegt
#10 Post by Billycar11 » Sat Aug 23, 2025 11:29 pm
tomcat1511 wrote: Sat Aug 23, 2025 1:39 pm My MakeMKV info section looks like this:
OS-Gerätename: H:
Produzent: HL-DT-ST
Revision: 1.03
Serienummer:
Follow bp50 nb 52 steps in guide
tomcat1511
#11 Post by tomcat1511 » Sun Aug 24, 2025 7:04 am
Even if my drive is BP *55* and not 50 or 52?
#12 Post by Billycar11 » Sun Aug 24, 2025 1:11 pm
tomcat1511 wrote: Sun Aug 24, 2025 7:04 am
look at the bottom its svc nb 52....
tomcat1511
#13 Post by tomcat1511 » Sun Aug 24, 2025 9:24 pm
Not sure what you are talking about - if you're speaking about the bottom of my drive, this is what it looks like:
LG Electronics
Slim Portable Blu-ray / DVD Writer
MODEL: BP55EB40
SVC CODE: EB40
S/N: 804HSCN006355
ROM VER: 1.01
Manufactured: April 2018
2018 04 09 Made in China
The only "SVC" thing I see there is "EB40".
Or what do you mean?
#14 Post by Billycar11 » Sun Aug 24, 2025 11:18 pm
Then don't flash it well you already did probably dead
#15 Post by MartyMcNuts » Mon Aug 25, 2025 12:52 am
OS-Gerätename: H:
Produzent: HL-DT-ST
Revision: 1.03
Serienummer:
The BP55 firmware does enable libredrive but is not UHD compatible. You now nee to cross-flash the drive to a UHD capable firmware such as BU40N 1.03-MK, BU40N 1.00 or BP60NB10 1.00-MK. Go to the SDFtool Flasher thread and read the section on SVC NB52, even though your's is SVC EB40. As you have already flashed the drive with the BP55EB40 1.03-MK firmware, just proceed from step 2. There's even a gif showing what to do.
