Robin Hood: Prince Of Thieves 1991-Arrow remastered blu-ray
duranduran
Post by duranduran » Sun Nov 26, 2023 9:36 am
Correct playlist for Robin Hood: Prince Of Thieves 1991 - Arrow remastered blu-ray
Can anyone help in regards to the correct playlist for both the theatrical and extended version of the movie?
thank you
JacobHeldt
Re: Robin Hood: Prince Of Thieves 1991-Arrow remastered blu-ray
Post by JacobHeldt » Fri Aug 22, 2025 9:37 pm
I Got the same issue. i even Got Libra Drive. can someone help?
Post by dcoke22 » Fri Aug 22, 2025 11:22 pm
DVDCompare.net (https://www.dvdcompare.net/comparisons/film.php?fid=62987) suggests the theatrical version is 143:12 and the extended version 155:02.
JacobHeldt
Post by JacobHeldt » Sat Aug 23, 2025 3:48 am
@dcoke22 - yes there are two cuts of the movie. problem is that there is a lot of playlists for each version when you rip the disc - even with libredrive and java installed.
JacobHeldt
Post by JacobHeldt » Sat Aug 23, 2025 1:30 pm
thank you
Did you ever find out?
JacobHeldt
Post by JacobHeldt » Sat Aug 23, 2025 1:36 pm
JacobHeldt
Post by JacobHeldt » Fri Aug 29, 2025 6:40 am
thank you
did you find the right one? thanks
JacobHeldt
Post by JacobHeldt » Fri Aug 29, 2025 6:59 am
as i wrote its a playlist issue - cause the disc has a large amount of playlist for each version - i have libredrive and Java installed - would you have any idea what to do?
thansk J
Post by dcoke22 » Fri Aug 29, 2025 2:27 pm
I don't have that disc, so I don't know what the proper playlists are. This thread has various methodologies you can try. A Better Way To Find The Correct Playlist/Segment Map
JacobHeldt
Post by JacobHeldt » Sat Aug 30, 2025 8:29 am
thanks a lot.
