some disc no matter what enviroment system is in are completely unreadable. system says no disc in drive. namely tv shows. it starts reading the drive then says no disc in drive. any ideas about this would be appreciated. thanks in advace
got to bolt mike out
some dvds are kicking makemkv system! read below.
mikebolt22
Re: some dvds are kicking makemkv system! read below.
If the disc doesn't appear, then it's a read problem, which means the drive can't see the disc, and has nothing to do with the OS. That means either the disc needs to be cleaned, or the drive itself is failing.
brandonyoung
It's possible that the DVDs are just bad. Warner Bros. had a lot of DVDs that just failed over time.
see here
https://forums.stevehoffman.tv/threads/ ... s.1197033/
see here
