some dvds are kicking makemkv system! read below.
mikebolt22
Post by mikebolt22 »
some disc no matter what enviroment system is in are completely unreadable. system says no disc in drive. namely tv shows. it starts reading the drive then says no disc in drive. any ideas about this would be appreciated. thanks in advace
got to bolt mike out
demon
Re: some dvds are kicking makemkv system! read below.
Post by demon »
If the disc doesn't appear, then it's a read problem, which means the drive can't see the disc, and has nothing to do with the OS. That means either the disc needs to be cleaned, or the drive itself is failing.
brandonyoung
Post by brandonyoung »
It's possible that the DVDs are just bad. Warner Bros. had a lot of DVDs that just failed over time.
see here
https://forums.stevehoffman.tv/threads/ ... s.1197033/
