I'm not exactly sure what this particular segment is, but is there a way to prevent this from happening again? I have plenty of disc space, so that's not the problem.Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/01218.m2ts' at offset '9972215808'
Failed to save title /BDMV/STREAM/01218.m2ts to file G:/Video/backup/Dune/BDMV/STREAM/01218.m2ts
Dune BD Backup Error
Dromeosaurid
I have a Pioneer BDR-XD05 and tried to back up my Dune (2021) disc. I received this error:
Re: Dune BD Backup Error
It looks like the drive may be struggling to read that disc, ran out of power and disappeared for a moment, enough for MakeMKV to throw that error.Dromeosaurid wrote: Sat Aug 23, 2025 1:10 am I have a Pioneer BDR-XD05 and tried to back up my Dune (2021) disc. I received this error:
Give the disc a good cleaning before attempting to rip it again.
Dromeosaurid
Thank you! I'll give it a proper cleaning and give it another go.
Dromeosaurid
I gave it a proper cleaning and it's still throwing the error message. I tried another disc altogether and it gave the same error message. It seems like the drive doesn't get enough power over USB for sustained reads. I had it connected to the front USB of my case, so it should be getting enough power I would think. Any other ideas?
I'm completely convinced that if you're using a Pioneer UHD drive that you should pump at least 30 watts to it, which is probably double the amount of power a old USB 3.0 port can supply. I have a USB powered Pioneer XD07 UHD drive and it's one of the most unreliable drives I have. It's 50/50 on if it's going to rip any given UHD. For some reason Pioneers require a huge amount of power and in this particular case (USB powered Pioneers) I'm not convinced that the circuit inside the drive could reliably draw enough power even if it was available.
It's the same with 5.25 drives. I have a Pioneer 212V and I had to switch to a OWC Mercury Pro external case from a Kanguru case because of the amount of power required.
Dromeosaurid
Interesting. I may look into connecting the secondary (non-data) USB connector to an external USB power supply if that's the case.flojo wrote: Sat Aug 23, 2025 4:53 pm I'm completely convinced that if you're using a Pioneer UHD drive that you should pump at least 30 watts to it, which is probably double the amount of power a old USB 3.0 port can supply. I have a USB powered Pioneer XD07 UHD drive and it's one of the most unreliable drives I have. It's 50/50 on if it's going to rip any given UHD. For some reason Pioneers require a huge amount of power and in this particular case (USB powered Pioneers) I'm not convinced that the circuit inside the drive could reliably draw enough power even if it was available.
Dromeosaurid
Looks like there is an external power adapter for the drive - even better!
https://www.amazon.com/MyVolts-Adaptor- ... NNZYJ?th=1
Hopefully that will solve the read errors.
Dromeosaurid
Update: just for grins I connected the drive directly to the rear USB ports of my motherboard and was able to rip without errors. I'm still going to order the external power adapter though.
Thanks all for the help!
Case ports are not recommended for use with optical drives. Ports direct from motherobard or an AC self powered USB hub 30w+ are recommended.Dromeosaurid wrote: Sat Aug 23, 2025 6:34 pm Update: just for grins I connected the drive directly to the rear USB ports of my motherboard and was able to rip without errors. I'm still going to order the external power adapter though.
