All Pioneer drives will be LibreDrive supported
Dromeosaurid
Re: All Pioneer drives will be LibreDrive supported
#136 Post by Dromeosaurid » Sat Aug 23, 2025 12:58 am
This is great news!
MovieNut
#137 Post by MovieNut » Sat Aug 23, 2025 6:59 am
Looking forward to this as well. I will have several Pioneer drives waiting. :wink:
VA1DER
#138 Post by VA1DER » Sat Aug 23, 2025 9:42 pm
MartyMcNuts wrote:
Tue Aug 19, 2025 10:58 pm
Yeah, but they most likely will be supported in the near future.
"Near" is open to interpretation. :roll:
That said...
Also, since Pioneer ceased manufacturing optical drives several months ago, the worlds supply is dwindling rather quickly!
The slimlne XS08 and even the UD04 you can still sort of get UHD-patchable versions of now are good drives, but actual S series 5. 25" drives are the best there are. I don't know how long before S12/S13 (or X12/X13) drives made after Dec 2022 will be libre drive patchable, but the consensus is they definitely will be. And when they are, what little stock there is of those drives now will turn into genuine unobtanium.
Now is the time to spring for one, or forever hold your peace.
cheeseballs
#139 Post by cheeseballs » Sat Aug 23, 2025 11:13 pm
This is probably a stupid question but will ask anyway-
Recently bought a random external drive on Amazon and it turned out to be a Pioneer BDR-206. I know Mike said 'all' Pioneer drives will be supported but I saw some older posts saying that only 208 or higher are UHD compatible. I'm still within my return window so wondering if I should return or hold onto it?
#140 Post by MartyMcNuts » Sat Aug 23, 2025 11:36 pm
If you want to rip UHD, return it. Even if it does get libredrive enabled, it still won't read UHD discs.
Mr_Orange
#141 Post by Mr_Orange » Sat Aug 23, 2025 11:45 pm
Where does the BDR-212DBK sit in the pecking order? Will this ever be UHD Libredrive?
#142 Post by MartyMcNuts » Sat Aug 23, 2025 11:49 pm
It's the base model, almost the same as the 212V. It can be cross-flashed for UHD redability.
bruce_ld
#143 Post by bruce_ld » Thu Sep 25, 2025 9:03 pm
I realize that the project of reverse engineering and bypassing the locked firmware must be extremely complex. However, I was wondering if there had been any updates on the timeline recently?
Thanks so much, mike!
-Bruce
pronouns: she/he
socdaemon
#144 Post by socdaemon » Fri Sep 26, 2025 1:41 am
+1, just here to share my appreciation for this effort! I'm patiently waiting for a way to unlock my BDR-XD08B for UHD :D
Thank you!!
DarkFiber
#145 Post by DarkFiber » Sat Oct 04, 2025 2:46 pm
Same here. I'm under no illusions that this will be a trivial hack, but it's almost exactly 5 months now, without any sort of update.
Is this still underway? Thanks! :)
Voxelium
#146 Post by Voxelium » Sun Oct 05, 2025 11:12 am
I stumbled across the following thread:
https://www.reddit.com/r/makemkv/commen ... t/nhi6gvh/
According to Billy, it looks like the wait is almost over. Fingers crossed my XS07S is compatible!
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
ttubbs
#147 Post by ttubbs » Sat Oct 11, 2025 4:30 am
Any more news on this? I already have an Asus BW-16D1HT and an LG slim. I would love to add a Pioneer to the lot.
Voxelium
#148 Post by Voxelium » Sun Oct 12, 2025 2:23 pm
Check that Reddit thread in the reply I made above yours.
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
ChameleonScales
#149 Post by ChameleonScales » Sun Oct 12, 2025 6:34 pm
Thank you so much for doing God's work.
I have a noob question : will this lift some hardware restrictions that some drives have? Specifically, I have a BDR-XS07UHD which requires specific Intel CPU and GPU tech but my PC has an AMD Ryzen 9 CPU + Nvidia 4090.
#150 Post by MartyMcNuts » Mon Oct 13, 2025 1:42 am
Hardware restrictions for what? If you are talking about UHD disc playback, although direct UHD disc playback is not recommended, it can be done on any decent spec PC (including yours) using any UHD compatible libredrive enabled drive via an unofficial player such as VLC, MPC_HC, Jriver, etc once integrated with MakeMKV.
