Sense and Sensibility 30th Anniversary UHD - Dump Submitted
ShoutingMan
#1 Post by ShoutingMan » Fri Aug 22, 2025 8:28 pm
New release: Sense and Sensibility 30th Anniversary UHD. I emailed the TGZ to the address in the sticky. I can't attach it here (board limit reached).
MakeMKV v1.18.1 win(x64-release) started
Debug logging enabled, log will be saved as
Using LibreDrive mode (v01.0 id=DFE22909F92F)
Downloading latest HK to C:\Users\D/.MakeMKV ...
Saved AACS dump file as C:\Users\D/.MakeMKV/MKB20_v82_Sense_and_Sensibility_ED9C.tgz
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213132721
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213131341
Re: Sense and Sensibility 30th Anniversary UHD - Dump Submitted
#2 Post by d00zah » Fri Aug 22, 2025 8:50 pm
From Public KeyDB Disc Submissions:
How can UHD discs be added to the public keydb?
Upload your disc dump file produced by one of the aforementioned drives to any file host and post the link in this thread.
Please do not directly attach disc dump files as this causes storage quota issues and a maintenance hassle for the forum administrators.
ShoutingMan
#3 Post by ShoutingMan » Fri Aug 22, 2025 9:19 pm
Yeah but there's another thread that was more obvious to me that says to try and upload the TGZ file:
viewtopic.php?f=12&t=35552
EDITED TO ADD: A change; dump files uploaded will be allowed temporarily, so that they can be pulled by other people who can process them for they keydb database. After they've been pulled, they will be removed.
Edited further to add: The board has a limit on size of files that can be uploaded. If your file is larger than that limit (figure about 4,000,000 bytes), you will get an error message. The work-around is to upload to a site that allows larger files (there are several around), and post the link in your message.
ShoutingMan
#4 Post by ShoutingMan » Fri Aug 22, 2025 9:20 pm
In any case, I also emailed the TGZ file to svq@makemkv.com like that thread said to.
if I should send it someplace else, please let me know. :)
#5 Post by d00zah » Fri Aug 22, 2025 9:23 pm
Nope. That's the 1st course of action. The KeyDB is a new(-ish) alternative, which might get more immediate results.
You reference a year-old topic. Times change.
ShoutingMan
#6 Post by ShoutingMan » Fri Aug 22, 2025 9:25 pm
Here's the TGZ file if this is better than that email address
https://www.dropbox.com/scl/fi/3rm4y2hl ... k1eu2&dl=0
ShoutingMan
#7 Post by ShoutingMan » Sat Aug 23, 2025 7:01 pm
So I found this post and downloaded the keydb.cfg into the MakeMKV folder.
viewtopic.php?p=162444#p162444
Then I found this post and installed KeyDB_Helper and did the Synchronize and Validate steps. It said my disc is known. So I re-ran MakeMKV and now it's ripping my disc. :)
viewtopic.php?p=166510#p166510
And I'm noting this here in case I wonder how I got this working in the future, I'lll find my old post and be reminded. :)
