New release: Sense and Sensibility 30th Anniversary UHD. I emailed the TGZ to the address in the sticky. I can't attach it here (board limit reached).
MakeMKV v1.18.1 win(x64-release) started
Debug logging enabled, log will be saved as
Using LibreDrive mode (v01.0 id=DFE22909F92F)
Downloading latest HK to C:\Users\D/.MakeMKV ...
Saved AACS dump file as C:\Users\D/.MakeMKV/MKB20_v82_Sense_and_Sensibility_ED9C.tgz
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213132721
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213131341
Sense and Sensibility 30th Anniversary UHD - Dump Submitted
ShoutingMan
Re: Sense and Sensibility 30th Anniversary UHD - Dump Submitted
From Public KeyDB Disc Submissions:ShoutingMan wrote: Fri Aug 22, 2025 8:28 pm New release: Sense and Sensibility 30th Anniversary UHD. I emailed the TGZ to the address in the sticky. I can't attach it here (board limit reached).
How can UHD discs be added to the public keydb?
Upload your disc dump file produced by one of the aforementioned drives to any file host and post the link in this thread.
Please do not directly attach disc dump files as this causes storage quota issues and a maintenance hassle for the forum administrators.
ShoutingMan
Yeah but there's another thread that was more obvious to me that says to try and upload the TGZ file:d00zah wrote: Fri Aug 22, 2025 8:50 pmFrom Public KeyDB Disc Submissions:ShoutingMan wrote: Fri Aug 22, 2025 8:28 pm New release: Sense and Sensibility 30th Anniversary UHD. I emailed the TGZ to the address in the sticky. I can't attach it here (board limit reached).
viewtopic.php?f=12&t=35552
EDITED TO ADD: A change; dump files uploaded will be allowed temporarily, so that they can be pulled by other people who can process them for they keydb database. After they've been pulled, they will be removed.
Edited further to add: The board has a limit on size of files that can be uploaded. If your file is larger than that limit (figure about 4,000,000 bytes), you will get an error message. The work-around is to upload to a site that allows larger files (there are several around), and post the link in your message.
ShoutingMan
In any case, I also emailed the TGZ file to svq@makemkv.com like that thread said to.
if I should send it someplace else, please let me know.
Nope. That's the 1st course of action. The KeyDB is a new(-ish) alternative, which might get more immediate results.
You reference a year-old topic. Times change.
ShoutingMan
Here's the TGZ file if this is better than that email address
https://www.dropbox.com/scl/fi/3rm4y2hl ... k1eu2&dl=0
ShoutingMan
So I found this post and downloaded the keydb.cfg into the MakeMKV folder.ShoutingMan wrote: Fri Aug 22, 2025 8:28 pm New release: Sense and Sensibility 30th Anniversary UHD. I emailed the TGZ to the address in the sticky. I can't attach it here (board limit reached).
viewtopic.php?p=162444#p162444
Then I found this post and installed KeyDB_Helper and did the Synchronize and Validate steps. It said my disc is known. So I re-ran MakeMKV and now it's ripping my disc.
viewtopic.php?p=166510#p166510
And I'm noting this here in case I wonder how I got this working in the future, I'lll find my old post and be reminded.
