AACS v82 dump - Japanese Blu-ray Disc
milkylucky
#1 Post by milkylucky » Thu Aug 21, 2025 12:06 pm
I tried to back up a Japanese Blu-ray disc with MakeMKV v1.18.1,
but it failed to decrypt. The log says:
"This disc uses newer version of AACS protection.
Saved AACS dump file...
Disc volume label code unknown - failed to decrypt."
I am attaching the AACS dump file generated by MakeMKV
(MKB_v82_Another.tgz).
Hopefully this can help update the key database.
Thank you! ! :)
Re: AACS v82 dump - Japanese Blu-ray Disc
#2 Post by MartyMcNuts » Fri Aug 22, 2025 1:49 am
Thank you! ! :)
Please don't try and attach dump files here.
The process is to email the tgz dump file to svq@makemkv.com so Mike can add a key for it to MakeMKV's hashed keys. Additionally, if you would like to also help the community, you can upload the dump file to a host somewhere, such as goolge drive, one drive, mediafire etc then post the download link here.
milkylucky
#3 Post by milkylucky » Fri Aug 22, 2025 5:02 am
Thank you for the reminder! I’ll send the tgz file to the email address as suggested.
