Blu-ray rip failure with no errors
bobburger
Post by bobburger » Fri Aug 22, 2025 1:24 am
I'm having trouble with a new dvd I received where it seems to be looping trying to parse a particular file with no output in the debug logs about it. It just seems to keep trying the same file indefinitely. Eventually it ends and it shows what seems to be hundreds of titles that are just the same 2 clips over and over. Any ideas or further debugging that I can do? I've attached a screen recording and the debug logs I collected. In the recording I did intervene to stop the disc reading early just to make the recording shorter.
https://drive.google.com/file/d/1-ZnoLh ... sp=sharing
Debug log started at Thu Aug 21 22:44:05 2025 , written by MakeMKV v1.18.1 darwin(arm64-release)
001005:0000 MakeMKV v1.18.1 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/andrew/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.7.1/(SecureTransport) LibreSSL/3.3.6/1.64.0 (x86_64-apple-darwin24.0) , proxy server not set.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.03 MOEOAM94749d" opened in OS access mode.
SDF  v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MOEOAM94749
001011:0000 Using LibreDrive mode (v06.3 id=866A98CB9C4E)
003305:0000 AACS directory not present, assuming unencrypted disc
Found java version=11.0.19 path=/Library/Java/JavaVirtualMachines/zulu-11.jdk/Contents/Home/bin/java
003344:0000 Using Java runtime from /Library/Java/JavaVirtualMachines/zulu-11.jdk/Contents/Home/bin/java
001003:0020 DEBUG: Code 0 at k"(>O2%~\ZkOq79sr_:213130007
001003:0020 DEBUG: Code 0 at k"(>O2%~\ZkOq79sr_:121263429
DEBUG: Code 0 at k"(>O2%~\ZkOq79sr_:121261474
DEBUG: Code 0 at JB&Q@/OI Uatc#6:121261980
001003:0020 DEBUG: Code 131078 at ,)\!/pz_N$)\w>$m[:121263843
001003:0020 DEBUG: Code 131078 at ,)\!/pz_N$)\w>$m[:121263107
001003:0020 DEBUG: Code 1 at ,)\!/pz_N$)\w>$m[:121263498
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00002.mpls was added as title #1
003307:0000 File 00003.mpls was added as title #2
003307:0000 File 00004.mpls was added as title #3
003025:0000 Title #00008.mpls has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00028.mpls was added as title #4
003307:0000 File 00031.mpls was added as title #5
003307:0000 File 00035.mpls was added as title #6
003307:0000 File 00037.mpls was added as title #7
003307:0000 File 00042.mpls was added as title #8
003307:0000 File 00045.mpls was added as title #9
003307:0000 File 00046.mpls was added as title #10
003307:0000 File 00049.mpls was added as title #11
003307:0000 File 00050.mpls was added as title #12
003307:0000 File 00051.mpls was added as title #13
003307:0000 File 00052.mpls was added as title #14
003307:0000 File 00053.mpls was added as title #15
003307:0000 File 00055.mpls was added as title #16
003307:0000 File 00057.mpls was added as title #17
003307:0000 File 00063.mpls was added as title #18
003307:0000 File 00065.mpls was added as title #19
003307:0000 File 00069.mpls was added as title #20
003307:0000 File 00070.mpls was added as title #21
003307:0000 File 00071.mpls was added as title #22
003307:0000 File 00074.mpls was added as title #23
003307:0000 File 00076.mpls was added as title #24
003307:0000 File 00077.mpls was added as title #25
003307:0000 File 00078.mpls was added as title #26
003307:0000 File 00081.mpls was added as title #27
003307:0000 File 00087.mpls was added as title #28
003307:0000 File 00089.mpls was added as title #29
003307:0000 File 00095.mpls was added as title #30
003307:0000 File 00097.mpls was added as title #31
003307:0000 File 00099.mpls was added as title #32
003307:0000 File 00102.mpls was added as title #33
003307:0000 File 00105.mpls was added as title #34
003307:0000 File 00106.mpls was added as title #35
003307:0000 File 00108.mpls was added as title #36
003307:0000 File 00109.mpls was added as title #37
003307:0000 File 00112.mpls was added as title #38
003307:0000 File 00116.mpls was added as title #39
003307:0000 File 00123.mpls was added as title #40
003307:0000 File 00124.mpls was added as title #41
003307:0000 File 00130.mpls was added as title #42
003307:0000 File 00130.mpls(2) was added as title #43
003307:0000 File 00130.mpls(3) was added as title #44
003307:0000 File 00131.mpls was added as title #45
003307:0000 File 00132.mpls was added as title #46
003307:0000 File 00133.mpls was added as title #47
003307:0000 File 00134.mpls was added as title #48
003307:0000 File 00135.mpls was added as title #49
003307:0000 File 00137.mpls was added as title #50
003307:0000 File 00138.mpls was added as title #51
003307:0000 File 00143.mpls was added as title #52
003307:0000 File 00144.mpls was added as title #53
003307:0000 File 00146.mpls was added as title #54
003307:0000 File 00147.mpls was added as title #55
003307:0000 File 00148.mpls was added as title #56
003307:0000 File 00149.mpls was added as title #57
003307:0000 File 00153.mpls was added as title #58
003307:0000 File 00154.mpls was added as title #59
003307:0000 File 00157.mpls was added as title #60
003307:0000 File 00158.mpls was added as title #61
003307:0000 File 00159.mpls was added as title #62
003307:0000 File 00160.mpls was added as title #63
003307:0000 File 00162.mpls was added as title #64
003307:0000 File 00165.mpls was added as title #65
003307:0000 File 00167.mpls was added as title #66
003307:0000 File 00172.mpls was added as title #67
003307:0000 File 00174.mpls was added as title #68
003307:0000 File 00175.mpls was added as title #69
003307:0000 File 00176.mpls was added as title #70
003307:0000 File 00177.mpls was added as title #71
003307:0000 File 00179.mpls was added as title #72
003307:0000 File 00188.mpls was added as title #73
003307:0000 File 00190.mpls was added as title #74
003307:0000 File 00192.mpls was added as title #75
003307:0000 File 00194.mpls was added as title #76
003307:0000 File 00195.mpls was added as title #77
003307:0000 File 00196.mpls was added as title #78
003307:0000 File 00197.mpls was added as title #79
003307:0000 File 00200.mpls was added as title #80
003307:0000 File 00204.mpls was added as title #81
003307:0000 File 00206.mpls was added as title #82
003307:0000 File 00209.mpls was added as title #83
003307:0000 File 00211.mpls was added as title #84
003307:0000 File 00213.mpls was added as title #85
003307:0000 File 00214.mpls was added as title #86
003307:0000 File 00215.mpls was added as title #87
003307:0000 File 00218.mpls was added as title #88
003307:0000 File 00223.mpls was added as title #89
003307:0000 File 00224.mpls was added as title #90
003307:0000 File 00229.mpls was added as title #91
003307:0000 File 00230.mpls was added as title #92
003307:0000 File 00231.mpls was added as title #93
003307:0000 File 00234.mpls was added as title #94
003307:0000 File 00240.mpls was added as title #95
003307:0000 File 00245.mpls was added as title #96
003307:0000 File 00246.mpls was added as title #97
003307:0000 File 00249.mpls was added as title #98
003307:0000 File 00250.mpls was added as title #99
003307:0000 File 00256.mpls was added as title #100
003307:0000 File 00258.mpls was added as title #101
003307:0000 File 00259.mpls was added as title #102
003307:0000 File 00263.mpls was added as title #103
003309:0000 Title 00264.mpls is equal to title 00213.mpls and was skipped
003307:0000 File 00269.mpls was added as title #104
003307:0000 File 00270.mpls was added as title #105
003307:0000 File 00273.mpls was added as title #106
003307:0000 File 00275.mpls was added as title #107
003307:0000 File 00277.mpls was added as title #108
003307:0000 File 00278.mpls was added as title #109
003307:0000 File 00280.mpls was added as title #110
003307:0000 File 00283.mpls was added as title #111
003309:0000 Title 00285.mpls is equal to title 00004.mpls and was skipped
003307:0000 File 00287.mpls was added as title #112
003307:0000 File 00288.mpls was added as title #113
003307:0000 File 00290.mpls was added as title #114
003307:0000 File 00293.mpls was added as title #115
003307:0000 File 00296.mpls was added as title #116
003309:0000 Title 00299.mpls is equal to title 00004.mpls and was skipped
003307:0000 File 00300.mpls was added as title #117
003307:0000 File 00302.mpls was added as title #118
003307:0000 File 00303.mpls was added as title #119
003307:0000 File 00304.mpls was added as title #120
003307:0000 File 00305.mpls was added as title #121
003307:0000 File 00306.mpls was added as title #122
003307:0000 File 00311.mpls was added as title #123
003307:0000 File 00317.mpls was added as title #124
003307:0000 File 00321.mpls was added as title #125
003307:0000 File 00322.mpls was added as title #126
003307:0000 File 00325.mpls was added as title #127
003307:0000 File 00330.mpls was added as title #128
003307:0000 File 00331.mpls was added as title #129
003309:0000 Title 00332.mpls is equal to title 00031.mpls and was skipped
003307:0000 File 00333.mpls was added as title #130
003307:0000 File 00336.mpls was added as title #131
003307:0000 File 00341.mpls was added as title #132
003309:0000 Title 00342.mpls is equal to title 00213.mpls and was skipped
003307:0000 File 00348.mpls was added as title #133
003307:0000 File 00352.mpls was added as title #134
003307:0000 File 00355.mpls was added as title #135
003307:0000 File 00361.mpls was added as title #136
003307:0000 File 00362.mpls was added as title #137
003307:0000 File 00363.mpls was added as title #138
003307:0000 File 00373.mpls was added as title #139
003307:0000 File 00374.mpls was added as title #140
003307:0000 File 00376.mpls was added as title #141
003307:0000 File 00379.mpls was added as title #142
003307:0000 File 00381.mpls was added as title #143
003307:0000 File 00384.mpls was added as title #144
003307:0000 File 00388.mpls was added as title #145
003307:0000 File 00389.mpls was added as title #146
003307:0000 File 00392.mpls was added as title #147
003307:0000 File 00393.mpls was added as title #148
003309:0000 Title 00397.mpls is equal to title 00288.mpls and was skipped
003307:0000 File 00398.mpls was added as title #149
003307:0000 File 00399.mpls was added as title #150
003307:0000 File 00401.mpls was added as title #151
003307:0000 File 00402.mpls was added as title #152
003307:0000 File 00405.mpls was added as title #153
003307:0000 File 00406.mpls was added as title #154
003307:0000 File 00408.mpls was added as title #155
003307:0000 File 00411.mpls was added as title #156
003309:0000 Title 00413.mpls is equal to title 00144.mpls and was skipped
003307:0000 File 00414.mpls was added as title #157
003307:0000 File 00416.mpls was added as title #158
003307:0000 File 00422.mpls was added as title #159
003307:0000 File 00425.mpls was added as title #160
003307:0000 File 00427.mpls was added as title #161
003307:0000 File 00430.mpls was added as title #162
003307:0000 File 00435.mpls was added as title #163
003309:0000 Title 00438.mpls is equal to title 00069.mpls and was skipped
003307:0000 File 00442.mpls was added as title #164
003307:0000 File 00446.mpls was added as title #165
003307:0000 File 00452.mpls was added as title #166
003309:0000 Title 00458.mpls is equal to title 00176.mpls and was skipped
003307:0000 File 00459.mpls was added as title #167
003307:0000 File 00461.mpls was added as title #168
003307:0000 File 00462.mpls was added as title #169
003307:0000 File 00463.mpls was added as title #170
003307:0000 File 00465.mpls was added as title #171
003307:0000 File 00466.mpls was added as title #172
003307:0000 File 00470.mpls was added as title #173
003307:0000 File 00471.mpls was added as title #174
003307:0000 File 00474.mpls was added as title #175
003307:0000 File 00475.mpls was added as title #176
003307:0000 File 00478.mpls was added as title #177
003307:0000 File 00479.mpls was added as title #178
003307:0000 File 00485.mpls was added as title #179
003307:0000 File 00491.mpls was added as title #180
003307:0000 File 00493.mpls was added as title #181
003307:0000 File 00495.mpls was added as title #182
003307:0000 File 00498.mpls was added as title #183
003307:0000 File 00501.mpls was added as title #184
003307:0000 File 00502.mpls was added as title #185
003309:0000 Title 00504.mpls is equal to title 00051.mpls and was skipped
003307:0000 File 00505.mpls was added as title #186
003307:0000 File 00507.mpls was added as title #187
003307:0000 File 00509.mpls was added as title #188
003307:0000 File 00512.mpls was added as title #189
003307:0000 File 00513.mpls was added as title #190
003307:0000 File 00517.mpls was added as title #191
003307:0000 File 00519.mpls was added as title #192
003307:0000 File 00524.mpls was added as title #193
003307:0000 File 00534.mpls was added as title #194
003307:0000 File 00536.mpls was added as title #195
003307:0000 File 00539.mpls was added as title #196
003307:0000 File 00542.mpls was added as title #197
003307:0000 File 00543.mpls was added as title #198
003307:0000 File 00544.mpls was added as title #199
003307:0000 File 00546.mpls was added as title #200
003309:0000 Title 00548.mpls is equal to title 00099.mpls and was skipped
003307:0000 File 00551.mpls was added as title #201
003309:0000 Title 00552.mpls is equal to title 00425.mpls and was skipped
003309:0000 Title 00553.mpls is equal to title 00190.mpls and was skipped
003307:0000 File 00554.mpls was added as title #202
003307:0000 File 00555.mpls was added as title #203
003307:0000 File 00556.mpls was added as title #204
003307:0000 File 00557.mpls was added as title #205
003307:0000 File 00558.mpls was added as title #206
003307:0000 File 00559.mpls was added as title #207
003307:0000 File 00561.mpls was added as title #208
003307:0000 File 00563.mpls was added as title #209
003307:0000 File 00573.mpls was added as title #210
003307:0000 File 00577.mpls was added as title #211
003307:0000 File 00578.mpls was added as title #212
003307:0000 File 00579.mpls was added as title #213
003307:0000 File 00585.mpls was added as title #214
003307:0000 File 00586.mpls was added as title #215
003307:0000 File 00589.mpls was added as title #216
003307:0000 File 00591.mpls was added as title #217
003307:0000 File 00596.mpls was added as title #218
003307:0000 File 00597.mpls was added as title #219
003307:0000 File 00601.mpls was added as title #220
003307:0000 File 00608.mpls was added as title #221
003307:0000 File 00613.mpls was added as title #222
003307:0000 File 00616.mpls was added as title #223
003307:0000 File 00624.mpls was added as title #224
003307:0000 File 00625.mpls was added as title #225
003307:0000 File 00626.mpls was added as title #226
003307:0000 File 00628.mpls was added as title #227
003307:0000 File 00630.mpls was added as title #228
003307:0000 File 00631.mpls was added as title #229
003307:0000 File 00632.mpls was added as title #230
003307:0000 File 00633.mpls was added as title #231
003307:0000 File 00635.mpls was added as title #232
003307:0000 File 00636.mpls was added as title #233
003307:0000 File 00638.mpls was added as title #234
003307:0000 File 00640.mpls was added as title #235
003307:0000 File 00641.mpls was added as title #236
003309:0000 Title 00642.mpls is equal to title 00188.mpls and was skipped
003307:0000 File 00647.mpls was added as title #237
003307:0000 File 00649.mpls was added as title #238
003307:0000 File 00651.mpls was added as title #239
003307:0000 File 00652.mpls was added as title #240
003307:0000 File 00654.mpls was added as title #241
003309:0000 Title 00655.mpls is equal to title 00065.mpls and was skipped
003307:0000 File 00656.mpls was added as title #242
003307:0000 File 00659.mpls was added as title #243
003307:0000 File 00665.mpls was added as title #244
003307:0000 File 00666.mpls was added as title #245
003307:0000 File 00667.mpls was added as title #246
003307:0000 File 00668.mpls was added as title #247
003307:0000 File 00669.mpls was added as title #248
003307:0000 File 00673.mpls was added as title #249
003307:0000 File 00677.mpls was added as title #250
003307:0000 File 00685.mpls was added as title #251
003307:0000 File 00688.mpls was added as title #252
003307:0000 File 00693.mpls was added as title #253
003307:0000 File 00694.mpls was added as title #254
003307:0000 File 00696.mpls was added as title #255
003307:0000 File 00697.mpls was added as title #256
003307:0000 File 00701.mpls was added as title #257
003307:0000 File 00703.mpls was added as title #258
003307:0000 File 00705.mpls was added as title #259
003307:0000 File 00707.mpls was added as title #260
003307:0000 File 00708.mpls was added as title #261
003309:0000 Title 00709.mpls is equal to title 00399.mpls and was skipped
003307:0000 File 00710.mpls was added as title #262
003307:0000 File 00713.mpls was added as title #263
003307:0000 File 00719.mpls was added as title #264
003307:0000 File 00720.mpls was added as title #265
003307:0000 File 00722.mpls was added as title #266
003307:0000 File 00723.mpls was added as title #267
003307:0000 File 00724.mpls was added as title #268
003307:0000 File 00726.mpls was added as title #269
003307:0000 File 00727.mpls was added as title #270
003307:0000 File 00729.mpls was added as title #271
003307:0000 File 00734.mpls was added as title #272
003307:0000 File 00736.mpls was added as title #273
003307:0000 File 00739.mpls was added as title #274
003307:0000 File 00742.mpls was added as title #275
003307:0000 File 00744.mpls was added as title #276
003307:0000 File 00746.mpls was added as title #277
003309:0000 Title 00747.mpls is equal to title 00148.mpls and was skipped
003307:0000 File 00748.mpls was added as title #278
003307:0000 File 00749.mpls was added as title #279
003307:0000 File 00752.mpls was added as title #280
003307:0000 File 00757.mpls was added as title #281
003307:0000 File 00758.mpls was added as title #282
003307:0000 File 00759.mpls was added as title #283
003307:0000 File 00763.mpls was added as title #284
003307:0000 File 00766.mpls was added as title #285
003307:0000 File 00769.mpls was added as title #286
003307:0000 File 00770.mpls was added as title #287
003307:0000 File 00775.mpls was added as title #288
003307:0000 File 00776.mpls was added as title #289
003307:0000 File 00778.mpls was added as title #290
003307:0000 File 00779.mpls was added as title #291
003307:0000 File 00780.mpls was added as title #292
003307:0000 File 00782.mpls was added as title #293
003307:0000 File 00783.mpls was added as title #294
003309:0000 Title 00784.mpls is equal to title 00002.mpls and was skipped
003307:0000 File 00786.mpls was added as title #295
003307:0000 File 00788.mpls was added as title #296
003309:0000 Title 00790.mpls is equal to title 00106.mpls and was skipped
003307:0000 File 00791.mpls was added as title #297
003307:0000 File 00793.mpls was added as title #298
003307:0000 File 00794.mpls was added as title #299
003307:0000 File 00797.mpls was added as title #300
003307:0000 File 00800.mpls was added as title #301
003307:0000 File 00803.mpls was added as title #302
003307:0000 File 00807.mpls was added as title #303
003307:0000 File 00809.mpls was added as title #304
003307:0000 File 00810.mpls was added as title #305
003307:0000 File 00816.mpls was added as title #306
003307:0000 File 00817.mpls was added as title #307
003307:0000 File 00818.mpls was added as title #308
003307:0000 File 00820.mpls was added as title #309
003307:0000 File 00828.mpls was added as title #310
003309:0000 Title 00829.mpls is equal to title 00719.mpls and was skipped
003307:0000 File 00834.mpls was added as title #311
003307:0000 File 00836.mpls was added as title #312
003307:0000 File 00837.mpls was added as title #313
003307:0000 File 00841.mpls was added as title #314
003307:0000 File 00844.mpls was added as title #315
003307:0000 File 00845.mpls was added as title #316
003307:0000 File 00847.mpls was added as title #317
003309:0000 Title 00850.mpls is equal to title 00116.mpls and was skipped
003307:0000 File 00851.mpls was added as title #318
003307:0000 File 00853.mpls was added as title #319
003307:0000 File 00857.mpls was added as title #320
003307:0000 File 00860.mpls was added as title #321
003307:0000 File 00865.mpls was added as title #322
003307:0000 File 00868.mpls was added as title #323
003307:0000 File 00869.mpls was added as title #324
003307:0000 File 00870.mpls was added as title #325
003307:0000 File 00872.mpls was added as title #326
003307:0000 File 00873.mpls was added as title #327
003307:0000 File 00877.mpls was added as title #328
003307:0000 File 00879.mpls was added as title #329
003307:0000 File 00880.mpls was added as title #330
003307:0000 File 00882.mpls was added as title #331
003307:0000 File 00884.mpls was added as title #332
003307:0000 File 00885.mpls was added as title #333
003309:0000 Title 00887.mpls is equal to title 00213.mpls and was skipped
003307:0000 File 00889.mpls was added as title #334
003309:0000 Title 00890.mpls is equal to title 00258.mpls and was skipped
003307:0000 File 00894.mpls was added as title #335
003307:0000 File 00895.mpls was added as title #336
003307:0000 File 00896.mpls was added as title #337
003307:0000 File 00897.mpls was added as title #338
003307:0000 File 00899.mpls was added as title #339
003307:0000 File 00901.mpls was added as title #340
003309:0000 Title 00904.mpls is equal to title 00322.mpls and was skipped
003307:0000 File 00906.mpls was added as title #341
003307:0000 File 00907.mpls was added as title #342
003307:0000 File 00909.mpls was added as title #343
003307:0000 File 00910.mpls was added as title #344
003307:0000 File 00912.mpls was added as title #345
003307:0000 File 00913.mpls was added as title #346
003309:0000 Title 00918.mpls is equal to title 00837.mpls and was skipped
003307:0000 File 00919.mpls was added as title #347
003307:0000 File 00922.mpls was added as title #348
003309:0000 Title 00932.mpls is equal to title 00177.mpls and was skipped
003307:0000 File 00933.mpls was added as title #349
003309:0000 Title 00935.mpls is equal to title 00882.mpls and was skipped
003307:0000 File 00939.mpls was added as title #350
003307:0000 File 00942.mpls was added as title #351
003307:0000 File 00943.mpls was added as title #352
003307:0000 File 00944.mpls was added as title #353
003307:0000 File 00945.mpls was added as title #354
003307:0000 File 00948.mpls was added as title #355
003307:0000 File 00949.mpls was added as title #356
003309:0000 Title 00951.mpls is equal to title 00097.mpls and was skipped
003307:0000 File 00952.mpls was added as title #357
003307:0000 File 00954.mpls was added as title #358
003307:0000 File 00957.mpls was added as title #359
003309:0000 Title 00959.mpls is equal to title 00479.mpls and was skipped
003309:0000 Title 00960.mpls is equal to title 00296.mpls and was skipped
003309:0000 Title 00962.mpls is equal to title 00651.mpls and was skipped
003307:0000 File 00965.mpls was added as title #360
003309:0000 Title 00966.mpls is equal to title 00188.mpls and was skipped
003307:0000 File 00969.mpls was added as title #361
003307:0000 File 00974.mpls was added as title #362
003307:0000 File 00976.mpls was added as title #363
003307:0000 File 00978.mpls was added as title #364
003307:0000 File 00982.mpls was added as title #365
003307:0000 File 00983.mpls was added as title #366
003307:0000 File 00984.mpls was added as title #367
003307:0000 File 00985.mpls was added as title #368
003307:0000 File 00986.mpls was added as title #369
003307:0000 File 00988.mpls was added as title #370
003307:0000 File 00992.mpls was added as title #371
003307:0000 File 00994.mpls was added as title #372
003307:0000 File 00999.mpls was added as title #373
003309:0000 Title 00002.m2ts is equal to title 00130.mpls(3) and was skipped
003025:0000 Title #00003.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00506.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00511.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 268435459 at ym'#bNEC_TGpk2JhrAB`%al-QAW:213130789
001003:0020 DEBUG: Code 2281701379 at SkVY[^[Mjt<aPqh$:121267293
... [The above two lines are repeated hundreds of times]
Re: Blu-ray rip failure with no errors
Post by Woodstock » Fri Aug 22, 2025 1:33 am
I get suspicious whenever I see this line with a commercial BD:
It's possible the disk has damage to it, which is why the scan takes forever. Mayhaps someone else has the same title, so we can figure out whether or not this is standard for it?
