Public KeyDB Disc Submissions
MKVDUDE
#256 Post by MKVDUDE » Thu Aug 21, 2025 2:52 pm
The Conjuring UK release - https://we.tl/t-0WvVAbfASM
Many thanks
cjw73
#257 Post by cjw73 » Thu Aug 21, 2025 3:01 pm
dump file for MKB20_v77_ERIN_BROCKOVICH_9FFA
https://drive.proton.me/urls/1PMZPZ1X5R#pbOnB18pclAH
thanks in advance :)
MKVDUDE
#258 Post by MKVDUDE » Thu Aug 21, 2025 3:21 pm
In the Mouth of Madness 4KUHD - https://we.tl/t-XpgnY8dErA
Many thanks
ryosukeHT
#259 Post by ryosukeHT » Thu Aug 21, 2025 4:23 pm
here is the dump file of a Japanese disc.
Hope you can help. Thanks!
https://1drv.ms/f/c/b5b2d73956188d16/Ej ... w?e=tTlb2A
Toad King
#260 Post by Toad King » Thu Aug 21, 2025 10:41 pm
EDIT: Nevermind, already in KeyDB
keydb_helper
#261 Post by keydb_helper » Thu Aug 21, 2025 10:50 pm
Thanks for the new disc dump files. These disc variants have been added to the public keydb:
Erin Brockovich - 9FFA
In The Mouth of Madness - 74E0
The Conjuring - 66FA
Dump for Erin Brockovich
Thanks for the disc dump file but the 0508 variant of Erin Brockovich should already be supported by the public keydb
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
cjw73
#262 Post by cjw73 » Thu Aug 21, 2025 11:11 pm
thanks again :)
#263 Post by SamuriHL » Thu Aug 21, 2025 11:54 pm
I've been away for a while but it would seem that a lot of people are posting dumps for discs that are already in the keydb. This is where my tool may be helpful. It'll use FindVUK to sync the keydb, and then the Disc Info button will display whether the disc is already supported in the keydb or not. If people used this function maybe it'll cut down on the dumps that are already there and people would be able to rip their discs even faster because you wouldn't have to wait for someone to tell you it's already there. You can find my tool here:
viewtopic.php?f=12&t=16883&p=166510#p166510
lolipeid47
#264 Post by lolipeid47 » Fri Aug 22, 2025 4:31 am
someone is currently the only person in the world helping us cracking UHD Discs. So all should take care of him. And all the people making him lose his time by giving dumps already cracked should be banned from the forum. It will serve them as a lesson.
cjw73
#265 Post by cjw73 » Fri Aug 22, 2025 9:43 am
that's a nice util you made there :) helps to add the new stuff to the database file when a key is added
biancaaq
#266 Post by biancaaq » Fri Aug 22, 2025 5:12 pm
I got this brand new Japanese bluray (雨の中の慾情), hope I'm doing it right:
https://www.dropbox.com/scl/fi/kq9zdtoo ... cyics&dl=0
mich52
#267 Post by mich52 » Fri Aug 22, 2025 5:29 pm
#269 Post by SamuriHL » Fri Aug 22, 2025 6:08 pm
It's mostly just a pretty UI for FindVUK. Nalor did us all a favor with that one but the problem I was trying to solve with my front end was syncing the keydb to MakeMKV. The Disc Info function is useful for seeing what the status of your disc is in the keydb without having to manually do anything. I find it useful for my own discs to know what's supported and what isn't. And since people tend to get discs WAY sooner than I do by the time mine arrive they're almost all already in the keydb. lol
#270 Post by Coopervid » Fri Aug 22, 2025 6:28 pm
Sam, I suggest that the initial post should be edited and Windows users should be motivated / encouraged to use your tool frequently to avoid circumstances like those. @keydb_helper.
