UHD Disc(s) - 4 nearly identical files?
kapqa
#1 Post by kapqa » Thu Aug 21, 2025 5:13 pm
Hello ,
i am new to UHD discs;
whenever attempting to backup/convert to Mkv via Makemkv , there seems to be surprise included,
now there are 2 discs and makemkv lists for both 4 title with the nearly same content (title, decription, Filesize , languages, subtitles, etc.)
only difference seems to be source file name and Segment map which is different for all 4 titles;
plus on Disc 2 , the last title, also a bit different on last title in filesize (56,1 vs 56,3 of the three other).
what should i make out of it?
is it indifferent which title to pick?
thank you very much.
https://ibb.co/xtqJ4Q82
https://ibb.co/Mqpp6yL
flojo
Re: UHD Disc(s) - 4 nearly identical files?
#2 Post by flojo » Thu Aug 21, 2025 5:29 pm
I *think* these are for different languages or locality of some type, like having the crawling text at the opening of Star Wars in German instead of English.
#3 Post by dcoke22 » Thu Aug 21, 2025 5:47 pm
My guess is flojo is probably right.
If you make a decrypted backup of the disc (the icon of the yellow folder with the green arrow on MakeMKV's first screen) you can play the segments from the segment map in a player like VLC. The files are in the <backup>/BDMV/STREAM/ folder.
You can open the backup in MakeMKV and create .mkv files from it, so you only have to copy data from the optical disc one time.
kapqa
#4 Post by kapqa » Fri Aug 22, 2025 7:16 am
alright, thanks, tried another approach,
making a backup of the UHD disc instead, but there are error included.
Backing up disc into folder "C:/Video/backup/THE_LAST_JEDI_4K"
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
#5 Post by dcoke22 » Fri Aug 22, 2025 11:02 pm
Have you backed/ripped up other 4K discs before? Asked another way, is your drive flashed to support LibreDrive and is it capable of ripping 4K discs?
I don't really know what those errors mean. I've never run into them personally.
Your hard drive didn't run out of space, right? :D
kapqa
#6 Post by kapqa » Sun Aug 24, 2025 7:58 pm
thanks, maybe the computer got into sleep mode, since i use "caffeine" app to avoid it from going to sleep when using makemkv for ripping dvd/bluray, but wasn't active.
it seems it made the backup nontheless; it is not an .iso file, but plays back well also from structure, very pleased!
in effect the 4 titles are the like-same, only the opening screen (and maybe final if there is) is in diffeent written language.
#7 Post by MartyMcNuts » Mon Aug 25, 2025 12:59 am
kapqa wrote: Sun Aug 24, 2025 7:58 pm thanks, maybe the computer got into sleep mode, since i use "caffeine" app to avoid it from going to sleep when using makemkv for ripping dvd/bluray, but wasn't active.
Whenever I am using MakeMKV, I always have a video playing on repeat so the PC stays active.
kapqa
#8 Post by kapqa » Mon Aug 25, 2025 9:28 am
it seems the error is not related to "suspend"
because it came back when i tried to open similar UHD disc
MakeMKV v1.18.1 linux(x64-release) started
Downloading latest SDF to /home/rich/.MakeMKV ...
Using LibreDrive mode (v01.0 id=2AE09FD4F501)
Title #01472.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00900.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00326.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00327.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00340.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00341.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00249.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
File 00802.mpls was added as title #2
Title #00001.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00313.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00314.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00333.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00341.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00810.m2ts was added as title #3
File 00811.m2ts was added as title #4
File 00812.m2ts was added as title #5
File 00813.m2ts was added as title #6
Saving 1 titles into directory /home/rich/Videos/Star Wars- The Last Jedi
1 titles saved
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Downloading latest HK to /home/rich/.MakeMKV ...
Title #00302.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00801.mpls was added as title #0
Title #00101.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00803.mpls was added as title #1
File 00004.mpls was added as title #2
Title #00002.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00802.mpls was added as title #3
Title #00902.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00301.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #4
Title #00016.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00151.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00004.mpls is equal to title 00800.mpls and was skipped
the drive is new, so maybe it is not patched to handle all disc and throws error?
however, it seems to be able to backup and rip dvd/bluray/UHD just fine.
it is LibreDrive enabled.
just one Bluray Backup fails to play (due to encryption issue) where the same movie backed up from UHD Version plays.
