Program Doesn't Read the Episode Titles in Some Discs
Ejfitz265
#1 Post by Ejfitz265 » Sat Aug 16, 2025 8:14 pm
I am having an issue with Ripping the Episodes for Have Gun Will Travel. The first five season went just fine. The first two discs in season 6 exhibited the behavior described below in the manual mode and debug file. But the 3 and 4th disc worked just fine. I tried to run the two discs in VLC player, and they played just fine. I also tried cleaning both discs that did not read correctly. The episode titles appear in mannual mode with correct times but do not appear when attempting to rip.
MakeMKV version (v1.18.1)
Drive model (Dell DW316)
What worked (Discs 3 and 4 OK)
What didn’t (Discs 1 and 2 only show dummy titles unless manual mode)
The Following was the Source information in Manual Mode: Disc Information Label : HAVE_GUN_WILL_TRAVEL_S6_V1_D1 Titles count : 16 Title information 1: 1/1 - 1 chapter(s) 0:00:16 1 cell(s) 2: 1/2 - 1 chapter(s) 0:00:05 1 cell(s) 3: 1/3 - 1 chapter(s) 0:00:00 1 cell(s) 4: 2/1 - 1 chapter(s) 0:00:00 1 cell(s) 5: 3/1 - 1 chapter(s) 0:03:09 4 cell(s) 6: 3/2 - 1 chapter(s) 0:00:00 1 cell(s) 7: 4/1 - 1 chapter(s) 0:25:36 6 cell(s) 8: 4/2 - 1 chapter(s) 0:25:36 6 cell(s) 9: 4/3 - 1 chapter(s) 0:25:36 6 cell(s) 10: 4/4 - 1 chapter(s) 0:25:37 6 cell(s) 11: 4/5 - 1 chapter(s) 0:25:37 6 cell(s) 12: 4/6 - 1 chapter(s) 0:25:37 6 cell(s) 13: 4/7 - 1 chapter(s) 0:25:38 6 cell(s) 14: 4/8 - 1 chapter(s) 0:25:37 6 cell(s) 15: 4/9 - 1 chapter(s) 3:24:58 48 cell(s) 16: 4/10 - 1 chapter(s) 0:00:00 1 cell(s)
The Following was the Debug file when i tried to open the disc: Debug log started at Sat Aug 16 17:14:59 2025 , written by MakeMKV v1.18.1 win(x64-release)
001005:0000 MakeMKV v1.18.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\ejfit/MakeMKV_log_1.txt
No SDF v098: Dell_DVD+/-RW_DW316_A1C3_202304101509_M04P16G0839
No auto SDF v098: Dell_DVD+/-RW_DW316_A1C3_202304101509_M04P16G0839
DEBUG: Code 0 at \c^YLv PcaLdd\XsJ:29396253
DEBUG: Code 0 at e!/TsMgD>)UEE0S:213136746
DEBUG: Code 3 at u%~+41nw7Z$>\(rT@7Hdjpjz:29395310
SDF id v098: Dell_DVD+/-RW_DW316_A1C3_202304101509_M04P16G0839
DEBUG: Code 0 at "_8Y~gp]N83/.*7Rw:121263199
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
DEBUG: Code 0 at n[Zy%v?9:72#^FwvnV]o:29396460
003025:0000 Title #1 has length of 16 seconds which is less than minimum title length of 70 seconds and was therefore skipped
003025:0000 Title #2 has length of 5 seconds which is less than minimum title length of 70 seconds and was therefore skipped
003038:0000 Cells 2-4 were removed from title end
003028:0000 Title #5 was added (1 cell(s), 0:01:16)
003038:0000 Cells 2-6 were removed from title end
003025:0000 Title #7 has length of 26 seconds which is less than minimum title length of 70 seconds and was therefore skipped
Title skip vts=4 pgcn=1
003025:0000 Title #8 has length of 27 seconds which is less than minimum title length of 70 seconds and was therefore skipped
Title skip vts=4 pgcn=2
003025:0000 Title #9 has length of 27 seconds which is less than minimum title length of 70 seconds and was therefore skipped
Title skip vts=4 pgcn=3
003025:0000 Title #10 has length of 26 seconds which is less than minimum title length of 70 seconds and was therefore skipped
Title skip vts=4 pgcn=4
003025:0000 Title #11 has length of 27 seconds which is less than minimum title length of 70 seconds and was therefore skipped
Title skip vts=4 pgcn=5
003025:0000 Title #12 has length of 27 seconds which is less than minimum title length of 70 seconds and was therefore skipped
Title skip vts=4 pgcn=6
003025:0000 Title #13 has length of 27 seconds which is less than minimum title length of 70 seconds and was therefore skipped
Title skip vts=4 pgcn=7
003025:0000 Title #14 has length of 27 seconds which is less than minimum title length of 70 seconds and was therefore skipped
Title skip vts=4 pgcn=8
003038:0000 Cells 2-48 were removed from title end
003025:0000 Title #15 has length of 26 seconds which is less than minimum title length of 70 seconds and was therefore skipped
Title skip vts=4 pgcn=9
Application exited at Sat Aug 16 17:17:33 2025
Any Ideas?
Re: Program Doesn't Read the Episode Titles in Some Discs
#2 Post by dcoke22 » Tue Aug 19, 2025 3:33 pm
I don't have any specific ideas regarding the problematic discs you describe. However, MakeMKV has various DVD Opening Modes that you can try.
Ejfitz265
#3 Post by Ejfitz265 » Thu Aug 21, 2025 12:22 pm
Thank you so much for your post. Using CellTrim did the trick. :)
