AACS v82 dump - Japanese Blu-ray Disc
milkylucky
Post by milkylucky »
I tried to back up a Japanese Blu-ray disc with MakeMKV v1.18.1,
but it failed to decrypt. The log says:
"This disc uses newer version of AACS protection.
Saved AACS dump file...
Disc volume label code unknown - failed to decrypt."
I am attaching the AACS dump file generated by MakeMKV
(MKB_v82_Another.tgz).
Hopefully this can help update the key database.
Thank you! ! :)
Re: AACS v82 dump - Japanese Blu-ray Disc
milkylucky wrote: Thu Aug 21, 2025 12:06 pm Hello,
Thank you! ! :)
Please don't try and attach dump files here.
The process is to email the tgz dump file to svq@makemkv.com so Mike can add a key for it to MakeMKV's hashed keys. Additionally, if you would like to also help the community, you can upload the dump file to a host somewhere, such as goolge drive, one drive, mediafire etc then post the download link here.
milkylucky
Thank you for the reminder! I’ll send the tgz file to the email address as suggested.
