The Conjuring 4k UHD Key File:
MKB20_v82_The_Conjuring_9B76.tgz
Google Drive Direct File Link:
https://drive.google.com/file/d/1s6NZGg ... drive_link
Dump Submitted - The Conjuring 4K UHD TGZ Key File
FootFungus07
Re: Dump Submitted - The Conjuring 4K UHD TGZ Key File
Greetings,
I have shared it as well as submitted via email.
Regards,
Regards,
keydb_helper
Thanks for the disc dump file. The 9B76 variant of The Conjuring has been added to the public keydb.FootFungus07 wrote: Thu Aug 21, 2025 12:32 am The Conjuring 4k UHD Key File:
(And thanks to everyone else who provided a disc dump file for this variant - it was surprisingly popular)
Public KeyDB Disc Submissions
I just submitted this again since it says the volume key is unknown. Internet access is enabled in my MakeMKV install, so if this has really been added to the database I'm not pulling it for some reason.
keydb_helper
The 9B76 variant of The Conjuring was added to the public keydb on August 21. This is a distinct source of keys compared to the native hashed keys which MakeMKV fetches automatically.creon wrote: Tue Aug 26, 2025 11:37 pm I just submitted this again since it says the volume key is unknown. Internet access is enabled in my MakeMKV install, so if this has really been added to the database I'm not pulling it for some reason.
If you'd like to configure MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
