Having issues updating key
GasMedium
Post by GasMedium » Thu Aug 14, 2025 6:49 pm
Hi all,
I am having trouble updating the registration key on my headless Linux server. I was originally on 1.17.9 when I got the “This application version is too old” error. I realized the issue was with the key not being updated so I waited until today but now that the new key is out and I am on 1.18.1, I am still receiving the error.
I have completely uninstalled, reinstalled, and attempted to update the key manually via ~/.MakeMKV/settings.conf (though this was a blank file). ChatGPT has been no help troubleshooting either.
I’m happy to post any error messages or terminal prompts but I’m semi new to this and I am really only seeing the “this application version is too old” error.
TLDR; I don’t know what I’m doing wrong when I try to update the registration key on my Linux server.
Re: Having issues updating key
Post by dcoke22 » Sat Aug 16, 2025 6:33 am
I don't use MakeMKV on a headless linux box, but I know others have had this trouble in the past.
https://forum.makemkv.com/forum/viewtopic.php?f=3&t=28684
There might be more threads, but that's the first one found.
16442496
Post by 16442496 » Sun Aug 17, 2025 5:03 am
I don't know about "headless server stuff", but does this help?
echo 'app_Key = "T-PuNYycrTTHW4QEOfhDrMuJMpojNqmY5CGuESAKXzHvwBvBcXhtsJLj4g6OAXd1zfzk"' >> ~/.MakeMKV/settings.conf
Debian 13
Xfce 4.20
MakeMKV 1.17.6 (Appimage)
2x Pioneer BD-ROM BDC-202
jwmarrs
Post by jwmarrs » Wed Aug 20, 2025 12:19 am
New to makemkv, but not to linux. Trying to get makemkvcon 1.18 working on a headless Debian installation (on a 2010 Mac Mini). I am getting the "This application version is too old" message:
jwm@Media-Server:~$ makemkvcon info
MakeMKV v1.18.1 linux(x64-release) started
Debug logging enabled, log will be saved as file:///home/jwm/MakeMKV_log.txt
This application version is too old.  Please download the latest version at http://www.makemkv.com/ or enter a registration key to continue using the current version.
I have placed the beta key here:
jwm@Media-Server:~$ cat .MakeMKV/settings.conf
app_key = "T-jsDE3X@ERyvYhavmw0qZ0oVC09x0EMwJ6y2QPwdXEkat28@C7VBXTtTIkNPab9AtV"
app_ShowDebug = "1"
I've tried both the beta key, as well as the key offered on this page (which is the key used above): https://www.makemkv.com/buy/
That page has this message:
Warning! August 2025 UPDATE: Came here because of the "program too old" message? This is our fault, the program will be updated soon. You don't have to buy it now in order to make it work, please use the free time-limited key below to activate the program. Or, if you really like the program and had a chance to try it - proceed with the purchase link below. Thanks!
So at this point, I'm going to wait it out, and see if they fix the bug that seems to be causing the problem in 1.18.
Post by Woodstock » Wed Aug 20, 2025 2:00 am
The key you posted is NOT the current key found in the message MakeMKV is free while in beta, so it won't work past July 31, 2025. Try it with the current key.
nypaulie
Post by nypaulie » Wed Aug 20, 2025 5:17 pm
The “newest” key I could find was good only until Jan ‘25. I was willing to shell out the $60, but I read that someone did that and still couldn’t get it to run so I set my clock back. This works!
nypaulie
Post by nypaulie » Wed Aug 20, 2025 5:28 pm
So what IS the current key?
Post by d00zah » Wed Aug 20, 2025 5:48 pm
2 posts up...
where it always is.You should bookmark it if you rely on the beta key.
jwmarrs
Post by jwmarrs » Thu Aug 21, 2025 3:25 am
 jwm@Media-Server:~$ makemkvcon reg T-PuNYycrTTHW4QEOfhDrMuJMpojNqmY5CGuESAKXzHvw
Key not found or invalid
app-key = "T-PuNYycrTTHW4QEOfhDrMuJMpojNqmY5CGuESAKXzHvwBvBcXhtsJLj4g6OAXd1zfzk"
app_ShowDebug = "1"
jwm@Media-Server:~$
rsion.
jwm@Media-Server:~$
Maybe the message on the "buy" page means there is a bug in `makemkvcon` 1.18?
Except, the key on that page doesn't seem to work either.
Or more likely, I'm doing it wrong or misunderstanding something (or both).
I did get the key from the beta page you linked working on macOS, in the makemkv UI. But my optical drive is on the other (headless Debian) machine.
16442496
Post by 16442496 » Thu Aug 21, 2025 7:15 am
I think it is that "app-Key"
And correct is "app_Key"
Check my post up.
Debian 13
Xfce 4.20
jwmarrs
Post by jwmarrs » Tue Aug 26, 2025 2:39 am
Check my post up.
Yes, this worked! "app_Key" and the current beta key in ~/.MakeMKV/settings.conf were successful. Thank you for your guidance, much appreciated.
nazifiibrahim
Post by nazifiibrahim » Wed Nov 26, 2025 1:43 am
Hi all,
Sounds like a frustrating loop — updating the key and the version should’ve fixed it. On Linux, MakeMKV can be picky about where the key is stored, so double-check permissions and make sure it’s actually writing to the correct config path. Posting the exact terminal output might help others spot what’s going wrong.
