BDR 212V UHD Guide
Frying-Tux
Re: BDR 212V UHD Guide
Hi Coopervid! I too would like a PM with instructions to get my drive working. Thank you!
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: XXXX
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 15
Firmware version: ID06
Revision: 1.02
Serial number: XXXX
PM sent. You need a Windows PC or VMWare under Linux. Not all VMs work.Frying-Tux wrote: Mon Aug 18, 2025 6:58 pm Hi Coopervid! I too would like a PM with instructions to get my drive working. Thank you!
Revision: 1.02
Serial number: XXXX
Hi there, Coopervid! I recently picked up a BDR-212V as a backup when I heard Pioneer was getting out of the business, and I'd like to get it working with LibreDrive. I'd appreciate hearing from you!
Revision: 1.02
Serial number: DGDL028725WL
Highest AACS version: 82
Good day @Coopervid,
I know this is an old post but hopefully you're still active
I have a Pioneer VD-RW BDR-212V still running Firmware 1.00
Could you please share your guidance!
Thank you
To play it safe post your Makemkv info.
Greetings Coopervid! I recently ordered a BD-RW BDR-212V to use before inventory dries up completely. I also would love some guidance.
Here is my info from makemkv
OS device name: E:
Revision: 1.02
Serial number: xxxxxxxxxxx
Thank you!
OS device name: E:
Revision: 1.02
Thank you!
PM sent.nfodiz wrote: Fri Aug 22, 2025 9:04 pm Greetings Coopervid! I recently ordered a BD-RW BDR-212V to use before inventory dries up completely. I also would love some guidance.
OS device name: E:
Revision: 1.02
Thank you!
Hi, Coopervid! I think my previous message waiting in the moderation queue (I'm a new registrant) means you might have missed it, and I can't send PMs yet, so sorry if this is repeating a message you've already seen.
Revision: 1.02
Serial number:
Yet another one
I can mount the drive and see the directory structure. So the drive appears to work, and this disc works fine in other drives.
Do we expect to get makemkv to do anything with this drive in stock form? Or is the reflash required for all types of discs?
Just curious. When I put a DVD in the drive, makemkv just spins trying to load the disc.Drive Information
Revision: 1.02
Serial number: DGDL028102WL
Highest AACS version: 68
Let the os see the disc first then open makemkvAndyA wrote: Sat Aug 23, 2025 10:23 pm Yet another oneJust curious. When I put a DVD in the drive, makemkv just spins trying to load the disc.Drive Information
Revision: 1.02
MakeMKV info tab:
OS device name: F:
Revision: 1.00
Serial number: AFDL013220WL
Firmware date: 2020-08-07
Highest AACS version: 70
Drive platform: RS8F00
Firmware version: 1.00/ID06
Please let me know if you need other information
Thank you
PM sent.vatov wrote: Sun Aug 24, 2025 10:39 amMakeMKV info tab:Coopervid wrote: Fri Aug 22, 2025 2:53 pmTo play it safe post your Makemkv info.vatov wrote: Fri Aug 22, 2025 2:11 pm
Thank you
OS device name: F:
Revision: 1.00
Thank you
Greetings @Coopervid
I saw this thread. I hope you're reading it. I just bought a Pioneer BDR-212V. I'm hoping these specs show that I'm able to flash its firmware
I hope this version is good. thank you in advance!
- Will
Current profile: DVD-ROM
Revision: 1.02
Serial number: REMOVED
- Will
PM sent.willkg118 wrote: Sun Aug 24, 2025 7:30 pm Greetings @Coopervid
I hope this version is good. thank you in advance!Code: Select all
Drive Information OS device name: \Device\CdRom0 Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: REMOVED Firmware date: 2022-05-31 Bus encryption flags: 13 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
- Will
Just joined the group and hope you can help me flash my drive.
Info follows:
OS device name: G:
Revision: 1.02
Serial number:
Thank you in advance
Info follows:
OS device name: G:
Revision: 1.02
Serial number:
