To old if your looking to do UHD 208 and newer for 5.25 drives and xd05 and newer for slims if you want UHDbigrippa4k wrote: ↑Mon Aug 18, 2025 7:15 pmRegarding the BDR-207's (specifically 207-DBK) what is the 'drive platform'? I found this model on marketplace for $20 and I'm considering taking the gamble but it sounds like most likely it will not be supported?
LibreDrive for Pioneer drives
Can this one do UHD?
OS device name: I:
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-X13
Revision: 1.04
Serial number: DIDL302071UC
Firmware date: 2023-08-01
Highest AACS version: 82
Drive platform: Pioneer RS9400
Firmware version: ID56
OS device name: I:
Revision: 1.04
Currently, no. The firmware is too new. Must be pre 12/2022. You will have to wait for future support.nd4spd81 wrote: ↑Wed Aug 20, 2025 3:01 amCan this one do UHD?
OS device name: I:
Revision: 1.04
Anything that can be done with this one?
OS device name: E:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number:
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 71
Firmware version: ID06
OS device name: E:
Revision: 1.02
Serial number:
Yes email that drive info see belowy2jdmbfan wrote: ↑Thu Aug 21, 2025 7:28 pmAnything that can be done with this one?
OS device name: E:
Revision: 1.02
Serial number:
Three drives:
... and am I right in thinking that all three of these need to wait for the promised Pioneer support that's coming and all of them are UHD-capable but will need a cross-flash to get it?
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Firmware date: 2023-04-20
Highest AACS version: 78
Firmware version: ID26
#2
Product: BD-RW BDR-XS07
Revision: 1.03
Firmware date: 2023-01-06
Drive platform: Pioneer RS8E20
Firmware version: GENE
#3
Revision: 1.03
Firmware version: GENE-
All of those must wait for future support.BeanJump wrote: ↑Sat Aug 23, 2025 2:10 amThree drives:... and am I right in thinking that all three of these need to wait for the promised Pioneer support that's coming and all of them are UHD-capable but will need a cross-flash to get it?Code: Select all
#1 Drive Information Manufacturer: ASUS Product: SBW-06D5H-U Revision: E102 Firmware date: 2023-04-20 Bus encryption flags: 1B Highest AACS version: 78 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8511 Firmware version: ID26 #2 Drive Information Manufacturer: PIONEER Product: BD-RW BDR-XS07 Revision: 1.03 Firmware date: 2023-01-06 Bus encryption flags: 13 Highest AACS version: 78 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8E20 Firmware version: GENE #3 Drive Information Manufacturer: PIONEER Product: BD-RW BDR-XS07 Revision: 1.03 Firmware date: 2023-01-06 Bus encryption flags: 13 Highest AACS version: 78 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8E20 Firmware version: GENE
TheDude_43
Hi Everyone,
I'm hoping someone can help me, because i'm unsure if my drive can read UHD.
I have read the flashing guide, but that leaves me more in teh dark, so im hoping someone would help me.
I have the following drive;
I have bought the ASUS-BW-16D1X-U External USB 3.0 Drive
MakeMKV Shows the following
OS device name: \Device\CdRom0 E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 19
Firmware version: ID76
Can this drive be flashed to read UHD?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent for UHD.TheDude_43 wrote: ↑Sat Aug 23, 2025 2:25 pmHi Everyone,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
TheDude_43
Thank you for the helpCoopervid wrote: ↑Sat Aug 23, 2025 4:24 pmPM sent for UHD.TheDude_43 wrote: ↑Sat Aug 23, 2025 2:25 pmHi Everyone,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
just picked up a Pioneer 212D
Product: BD-RW BDR-212D
Revision: 1.02
Serial number:
Firmware date: 2022-03-16
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.02/ID61
I can rip standard BD but can't read UHD. Assuming it's possible from what I read but where is the firmware?
TIA
Revision: 1.02
Serial number:
TIA
PM sent.Tok72 wrote: ↑Sun Aug 24, 2025 8:28 pmjust picked up a Pioneer 212D
Revision: 1.02
Serial number:
TIA
Howdy, everyone. First post.
Long time lurker, been gathering up some tools to work with. Now I'm ready, need some assistance.
Current profile: DVD+R
Revision: 1.02
Serial number: DGDL028002WL
Thanks in advance!
Revision: 1.02
Thanks in advance!
sure just email me that info see below for emailTrailer98 wrote: ↑Mon Aug 25, 2025 2:23 amHowdy, everyone. First post.
Revision: 1.02
Thanks in advance!
