How to fix the reading errors? I get errors only on specific Blu Ray Discs.
White_Gandalf42
Post by White_Gandalf42 » Sun Aug 17, 2025 9:47 am
I am using a techpulse120 drive with libre drive enabled. So far I could process all of my dvd and blu ray discs, but one.
I tried cleaning the disc multiple times, but the errors persist. I noted that the errors occured at different positions each time I tried to rip the disc. Is this an indication, that the errors are fixable?
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.00
Serienummer: MOANBID4909
Firmware-Datum: 2116-12-20 15:28
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 10
Firmware version: 1.00
Disk-Informationen
Label: ESCAPE_PLANET_APES
Zeitstempel: 2008-11-12 08:14:16
Schutz: AACS v9, BD+ v2008.11
Datenkapazität: 32.62 Gb
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Kanal-Bitlänge: 74,5 nm (max. 25.0 GB pro Layer)
Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00013.m2ts' bei Offset '5734858752'
Fehler 'Betriebssystemfehler - STATUS_DEVICE_DATA_ERROR' trat auf während des Auslesens von '\Device\CdRom0' bei Offset '5734858752'
Thanks for your help.
Kind regards
Robert
Rosebl
Re: How to fix the reading errors? I get errors only on specific Blu Ray Discs.
Post by Rosebl » Wed Aug 20, 2025 3:46 am
It appears that your drive and LibreDrive setup are functioning properly, but those shifting read errors typically indicate a potential disc issue—either minor scratches, dirt in the protective layer, or manufacturing defects. If cleaning doesn’t help, try lowering the read speed (using MakeMKV or tools like AnyDVD/ImgBurn) or another drive, since some drives handle bad sectors better. If errors keep moving around, it often means the disc is physically marginal, but sometimes still ripable with patience and multiple passes.
White_Gandalf42
Post by White_Gandalf42 » Wed Aug 20, 2025 2:24 pm
Changing speed and/or read buffer size didn't change the result. I tried another ten times to rip the Blu Ray disc.
AnyDVD is not supported anymore, so I won't try it.
Therefore, I am still stuck with the error and it's changing offset locations.
Any more ideas, that I can try?
Post by MartyMcNuts » Wed Aug 20, 2025 10:31 pm
White_Gandalf42 wrote: Wed Aug 20, 2025 2:24 pm Changing speed and/or read buffer size didn't change the result. I tried another ten times to rip the Blu Ray disc.
If a thorough cleaning of the disc with soapy water doesn't help, it's probably a faulty disc.
