FURIOSA_A_MAD_MAX_SAGA 'MEDIUM ERROR: L- EC UNCORRECTABLE ERROR' with 2 different discs at exact same offset
warwolf7
#1 Post by warwolf7 » Tue Aug 12, 2025 12:47 pm
I bought FURIOSA_A_MAD_MAX_SAGA, UHD i get the error
Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLZJASJ3717' at offset '33645985792'
I tried multiple times, rebooted the computer just in case. Exchange the disc to get another disc, but I get the same error at the exact same offset. I can still rip other UHD, the drive does not seems to be problematic.
Makemkv 1.18.1 using a docker on linux on unraid.
BD-RE WH16NS60 - firmwarev 1.02
retry count is set at 30
Different disc with same error at same offset, makes me believe something not right on the drive or software side. Is there anything I can do other than buying a new drive to try to rip it?
this thread viewtopic.php?f=8&t=15055 mentions : "The first thing to know is that by the time you’ve seen one of these messages, the disc has been successfully decrypted so the problem is NOT decryption-related." but If I understand my logs properly, it happens while it's decrypting the UHD.
[autodiscripper] Disc detected in drive 0 (/dev/sr0): FURIOSA_A_MAD_MAX_SAGA.
[autodiscripper] Starting disc rip...
[autodiscripper] [makemkvcon] MakeMKV v1.18.1 linux(x64-release) started
[autodiscripper] [makemkvcon] Debug logging enabled
[autodiscripper] [makemkvcon] Current operation: Scanning CD-ROM devices
[autodiscripper] [makemkvcon] Current action: Scanning CD-ROM devices
[autodiscripper] [makemkvcon] Current progress - 0%, Total progress - 0%
[autodiscripper] [makemkvcon] DEBUG: Code 0 at *s
[autodiscripper] [makemkvcon] DEBUG: Code 2 at _2UmdXgB+Xm61zw0#yW]:213129892
[autodiscripper] [makemkvcon] DEBUG: Code 0 at Ju?+1@8J#3Jv`d^:213130329
[autodiscripper] [makemkvcon] Current progress - 100%, Total progress - 0%
[autodiscripper] [makemkvcon] Current progress - 100%, Total progress - 100%
[autodiscripper] [makemkvcon] Current progress - 0%, Total progress - 100%
[autodiscripper] [makemkvcon] Using LibreDrive mode (v06.3 id=7FA2657C7667)
[autodiscripper] [makemkvcon] Using direct disc access mode
[autodiscripper] [makemkvcon] Current operation: Opening Blu-ray disc
[autodiscripper] [makemkvcon] Current action: Processing AV clips
[autodiscripper] [makemkvcon] Current progress - 72%, Total progress - 0%
[autodiscripper] [makemkvcon] Current progress - 72%, Total progress - 4%
[autodiscripper] [makemkvcon] Current action: Processing movie playlists
[autodiscripper] [makemkvcon] Current progress - 0%, Total progress - 4%
[autodiscripper] [makemkvcon] Current progress - 85%, Total progress - 4%
[autodiscripper] [makemkvcon] Current progress - 85%, Total progress - 10%
[autodiscripper] [makemkvcon] Current progress - 100%, Total progress - 10%
[autodiscripper] [makemkvcon] Current progress - 100%, Total progress - 11%
[autodiscripper] [makemkvcon] Current action: Decrypting
[autodiscripper] [makemkvcon] Current progress - 0%, Total progress - 11%
[autodiscripper] [makemkvcon] Current progress - 14%, Total progress - 11%
[autodiscripper] [makemkvcon] Current progress - 14%, Total progress - 13%
[autodiscripper] [makemkvcon] Current progress - 25%, Total progress - 13%
[autodiscripper] [makemkvcon] Current progress - 25%, Total progress - 14%
[autodiscripper] [makemkvcon] Current progress - 37%, Total progress - 14%
[autodiscripper] [makemkvcon] Current progress - 37%, Total progress - 15%
[autodiscripper] [makemkvcon] DEBUG: Code 100864261 at fPU]a<H}AGNFc7Vv\w:121263429
[autodiscripper] [makemkvcon] DEBUG: Code 100864261 at fPU]a<H}AGNFc7Vv\w:121262302
[autodiscripper] [makemkvcon] Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.02 KLZJASJ3717' at offset '33645985792'
[autodiscripper] Killed
[autodiscripper] Disc rip terminated with failure.
from MakeMKV_log.txt
Debug log started at Tue Aug 12 12:43:20 2025 , written by MakeMKV v1.18.1 linux(x64-release)
001005:0000 MakeMKV v1.18.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///config/MakeMKV_log.txt
Using 6144KB for read cache.
Network access is ENABLED, CURL version 7.88.1/OpenSSL/3.0.16/1.52.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 2 at _2UmdXgB+Xm61zw0#yW]:213129892
001003:0020 DEBUG: Code 0 at Ju?+1@8J#3Jv`d^:213130329
001003:0020 DEBUG: Code 0 at *s,+4m-r">yFd&'k/Y<sa&:29393631
SDF  v098: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLZJASJ3717
Re: FURIOSA_A_MAD_MAX_SAGA 'MEDIUM ERROR: L- EC UNCORRECTABLE ERROR' with 2 different discs at exact same offset
#2 Post by dcoke22 » Sat Aug 16, 2025 6:47 am
That's a triple layer disc. Is the drive struggling at the layer break? That might explain why it fails at the same offset on two discs.
Can the drive rip other triple-layer 4K UHDs?
warwolf7
#3 Post by warwolf7 » Mon Aug 18, 2025 2:30 pm
Hi @dcoke22, thank you for answering
according to a search engine
examine the reflective side of the disc, near the center hole, for rings or patterns. Dual-layer discs will have two rings with markings, while triple-layer discs will have three
I'm was previously able to rip Horizon UHD HDR disc which if I understood properly, is a triple layer disc.
After my failed attemps at ripping furiosa, I tried to rip Horizon disc again, and it worked. That makes me think that the drive is not on it's way to the grave yet.
#4 Post by dcoke22 » Mon Aug 18, 2025 6:04 pm
MakeMKV will tell you how many layers a disc is. After you put in the disc and let MakeMKV read it (on MakeMKV's first screen), the information on the right will include how much data is on the disc and how many layers.
In any case, this error
generally means that the optical drive was unable to correctly read that spot on the disc. The standard advice is to gently clean the disc and try again. Even if the disc is brand new, a good cleaning can help. Sometimes there are nearly invisible deposits on the disc either left over from the manufacturing process or as the result of off gassing of the plastic case that holds the disc.
Your next best option is a second drive. In my experience, some drives just don't like some discs. Personally, I'm up to four drives on my desk now. There is rarely a disc that can't be read by at least one of my drives. In the rare cases where I can't read a disc, a replacement disc has always worked.
warwolf7
#5 Post by warwolf7 » Wed Aug 20, 2025 4:19 pm
Thank you,
I did try to wipe the disc, I went back to wallmart to exchange it too, but those steps did not resolve the issue. I guess I need to buy another drive.
Can you suggest a drive that would have more chance at reading that disc when my LG doesn't ready it. Should I go with another LG or Pionner or Asus?
Thank you for your help, it's very appreciated.
#6 Post by dcoke22 » Wed Aug 20, 2025 4:36 pm
Pioneers are held in high regard. Unfortunately, Pioneer has stopped making optical drives and supplies of new drives are dwindling.
Further complicating matters, Pioneer drives with firmware from December 2022 or later prevents the drives from working with LibreDrive.
Mike has stated that eventually all Pioneer drives will be made to work, but there's no ETA. https://forum.makemkv.com/forum/viewtopic.php?p=174108#p174108
To be clear, for a Pioneer drive to rip UHDs, it needs to support reading UHDs. If you look around the forum, you'll see people with older Pioneer drives that currently do not support UHD (even if they do support LibreDrive), but many of those drives can be flashed to be a Pioneer model that does support reading UHDs. To rip UHDs, the drive has to support reading UHDs and the drive's firmware has to support LibreDrive.
A seller in your region might have a Pioneer drive with the correct firmware. I have lost track of who has what stock left.
If tracking down a Pioneer seems like too much work, the next best thing is probably a LG BU40N based drive. That's LG's mobile drive platform, but it generally is considered better than LG's desktop platform these days.
y3kt07
#7 Post by y3kt07 » Wed Aug 20, 2025 6:22 pm
I just finished ripping my FURIOSA_A_MAD_MAX_SAGA disc without issues on a Pioneer XS07S, so everything seems to point to a drive issue.
OS device name: /dev/rdisk4
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.01
Serial number: TLXXXXXXXUC
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8E21
Firmware version: 1.01/ID05
Disc Information
Label: FURIOSA_A_MAD_MAX_SAGA
Timestamp: 2024-06-24 16:22:41
Protection: AACS2.0/C v77
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
warwolf7
#8 Post by warwolf7 » Wed Aug 20, 2025 11:45 pm
Thanks guys! That's very much appreciated!
I'll try option #5 from this seller viewtopic.php?f=20&t=21354
I'll try to report back when I get it.
