Pioneer BDR-XS06
VulcanCCIT
Pioneer BDR-XS06
Post by VulcanCCIT » Mon Aug 18, 2025 4:43 am
Not new to flashing devices really, but new to flashing drives with the SDFTool Flasher. So as I read the info about flashing...Pioneer drives may work and flashing may be supported in the future. There was a line in there that if the Drive works now, do not flash... Meaning if it works as a drive but does not work for UHD? That is my case.
MakeMKV shows this about the drive:
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-XS06
Revision: 1.10
Serial number: RADL022586UC
Firmware date: 2017-06-22
Bus encryption flags: 13
Drive platform: RS8722
Firmware name: PIONEER BDR-XS06
Firmware version: 1.10
I ordered this on Amazon October of 2018.
So I am not sure if it is flashable currently. If so, which firmware? I downloaded the "Everything" firmware pack.
Thank you all in advanced for your guidance on this.
Re: Pioneer BDR-XS06
Post by Billycar11 » Mon Aug 18, 2025 4:56 am
there is currently no UHD fw for that drive but that may change soon
Post by Coopervid » Mon Aug 18, 2025 8:44 am
Most likely this drive will never read UHDs since there was never any UHD capable one based on this hardware type.
VulcanCCIT
Post by VulcanCCIT » Mon Aug 18, 2025 10:52 pm
Thank you Billy and Cooper! Between this forum. the MakeMKV Reddit group and the posts by Cooper and Billy I have learned a lot in less than 24 hours. I thought that if the drive could read a UHD, it could rip one. I now see why they need flashed. This drive does not even read a UHD. It has been great for DVDs and Bluray in general though. I see via the Reddit group that Billy is out of drives at this time but I probably will nab one when he has them for sale again. I appreciate your time on all of this!
VulcanCCIT
Post by VulcanCCIT » Mon Aug 18, 2025 11:50 pm
@Billycar11 Is there a post I can subscribe to that will let me know when your drives will be available again? I saw you are testing some via your reddit post. Thank you sir!
Post by Billycar11 » Tue Aug 19, 2025 11:58 am
VulcanCCIT wrote: Mon Aug 18, 2025 11:50 pm @Billycar11 Is there a post I can subscribe to that will let me know when your drives will be available again? I saw you are testing some via your reddit post. Thank you sir!
Yes you can subscribe to my posts
i will post when they are for sale
https://www.reddit.com/r/makemkv/commen ... usbcsleep/
viewtopic.php?f=20&t=17831
