Not new to flashing devices really, but new to flashing drives with the SDFTool Flasher. So as I read the info about flashing...Pioneer drives may work and flashing may be supported in the future. There was a line in there that if the Drive works now, do not flash... Meaning if it works as a drive but does not work for UHD? That is my case.
MakeMKV shows this about the drive:
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-XS06
Revision: 1.10
Serial number: RADL022586UC
Firmware date: 2017-06-22
Bus encryption flags: 13
Drive platform: RS8722
Firmware name: PIONEER BDR-XS06
Firmware version: 1.10
I ordered this on Amazon October of 2018.
So I am not sure if it is flashable currently. If so, which firmware? I downloaded the "Everything" firmware pack.
Thank you all in advanced for your guidance on this.
Pioneer BDR-XS06
Re: Pioneer BDR-XS06
there is currently no UHD fw for that drive but that may change soon
Most likely this drive will never read UHDs since there was never any UHD capable one based on this hardware type.
VulcanCCIT
Thank you Billy and Cooper! Between this forum. the MakeMKV Reddit group and the posts by Cooper and Billy I have learned a lot in less than 24 hours. I thought that if the drive could read a UHD, it could rip one. I now see why they need flashed. This drive does not even read a UHD. It has been great for DVDs and Bluray in general though. I see via the Reddit group that Billy is out of drives at this time but I probably will nab one when he has them for sale again. I appreciate your time on all of this!
VulcanCCIT
@Billycar11 Is there a post I can subscribe to that will let me know when your drives will be available again? I saw you are testing some via your reddit post. Thank you sir!
Yes you can subscribe to my postsVulcanCCIT wrote: Mon Aug 18, 2025 11:50 pm @Billycar11 Is there a post I can subscribe to that will let me know when your drives will be available again? I saw you are testing some via your reddit post. Thank you sir!
i will post when they are for sale
https://www.reddit.com/r/makemkv/commen ... usbcsleep/
viewtopic.php?f=20&t=17831
