Spider-Man (2002) 4K Blu-ray Giving Read Errors Only in MakeMKV
YouAcheDee
#1 Post by YouAcheDee » Sun Aug 17, 2025 7:42 pm
As the title says, MakeMKV won't rip my Spider-Man (2002) disc and keeps giving read errors.
I have ripped Spider-Man into the Spider-Verse on 4k bluray, and many DVD's as well as at least 5 Blu-rays, with MakeMKV without any problems.
I don't think the disc is flawed, because it plays in VLC with MakeMKV integration, but just will not convert to a MKV file in MakeMKV. The main feature, which is what I am wanting to rip, is shown in the titles menu after opening the disc, but MakeMKV gives several read errors when trying to convert the content.
I have already cleaned the laser on my LG BU40N drive, which I am using to read the disc, but I would like to know if anyone has any potential fixes to the problem in MakeMKV.
Blyth
Re: Spider-Man (2002) 4K Blu-ray Giving Read Errors Only in MakeMKV
#2 Post by Blyth » Sun Aug 17, 2025 7:50 pm
What have you cleaned the disc with? Soap and water does absolutely nothing for me when I have had problem discs, What works for me is specs eye glass cleaner, good job I wear glasses lol
YouAcheDee
#3 Post by YouAcheDee » Sun Aug 17, 2025 8:00 pm
I didn't clean the disc considering it is brand new and reads properly in VLC. I cleaned my LG BU40N's lasers by rubbing a Q-tip with 70% isopropyl alcohol on it.
Blyth
#4 Post by Blyth » Sun Aug 17, 2025 8:20 pm
You need to clean the disc that's the first thing to try, doesn't matter if it's new or if it plays in VLC.
YouAcheDee
#5 Post by YouAcheDee » Sun Aug 17, 2025 8:28 pm
Thanks, should I try cleaning the disc with a clean microfiber cloth or the same isopropyl alcohol I cleaned the lasers with?
Blyth
#6 Post by Blyth » Sun Aug 17, 2025 8:39 pm
Yes that's right give that a go, I had a problem disc had to clean it four times but it was a old disc.
It's your choice what cleaner to use but soap never works for me, you can use what you used to clean the laser just use a clean microfiber cloth.
YouAcheDee
#7 Post by YouAcheDee » Tue Aug 19, 2025 2:09 pm
Thanks for the advice. I cleaned the disc with a microfiber cloth first by just wiping off the surface, but that didn't seem to do anything. After the microfiber cloth, I decided to try using a cotton ball soaked with isopropyl alcohol which didn't change anything either.
I am almost certain the disc is faulty, so I am now attempting to get a replacement.
Blyth
#8 Post by Blyth » Tue Aug 19, 2025 3:54 pm
That's a shame it didn't work, hopefully the new disc will work, does it fail to rip straight away? if it fails again when you get the new disc post the debug log and I'm sure people will able to see what's going on and help, but that's always the first stage is to clean a problem disc even if it's new, that's why I always rip a disc straight away without waiting to watch it.
YouAcheDee
#9 Post by YouAcheDee » Fri Aug 22, 2025 1:35 pm
Sorry for the late reply. The disc doesn't fail to rip straight away. MakeMKV starts reading the disc normally then climbs to huge hour time estimates (like 12+ hours) then gives a lot of read errors. The store I ordered the disc from told me that every one of their discs for that particular movie were faulty from the factory, so I wouldn't be able to get a replacement. The store did however give me a full refund for the whole Raimi trilogy bundle I ordered the Spider-Man (2002) 4k Blu-ray in for the inconvenience and didn't make me send the faulty disc back. The other 2 movies in the bundle work flawlessly, but the first movie is unusable for ripping.
Blyth
#10 Post by Blyth » Fri Aug 22, 2025 4:10 pm
Shame sounds like a defective disc then, as it's just one disc I would keep on cleaning it to see if it it will just about manage the rip. it's frustrating when it happens so far I have managed to get my discs ripped by cleaning and cleaning.
Post up the errors here just to make sure it's a read error.
YouAcheDee
#11 Post by YouAcheDee » Wed Aug 27, 2025 3:26 pm
I have cleaned the disc even more since I made the original post. Earlier this year I found a Scotch CD Radial Cleaner that fully functions, and today I tried cleaning the disc with that, twice, without success. I do not have error logs turned on for the version of MakeMKV I was attempting to rip this disc with, but I do have a picture of the error codes the app repeatedly gave me, which I used a tool to transcribe.
Also, I have linked am eBay listing of the CD Cleaner product I was referring to, so you know what product I used.
Listing:
https://www.ebay.com/itm/145796769396
Error Codes:
MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808187904' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808187904' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808187904'
MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808255488' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808255488' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808255488' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808255488' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808255488' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo at offset '808255488'
MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808316928' MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808452096' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808452096' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo' at offset '808452096' MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808513536' MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808581120' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo' at offset '808581120' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo at offset '808581120' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo' at offset '808581120' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo' at offset '808581120' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo at offset '808581120' MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808581120' MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808581120' MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808581120' MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808581120' MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808581120' MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808581120' MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808581120'
Error Scsi error
Error 'OS error
3
Error 'OS error
4
Error 'Scsi error
5
Error 'OS error
6
Error 'OS error
7
Error 'OS error
8
Error 'OS error
9
Error 'OS error
10
Error 'Scsi error
11
Error 'Scsi error
12
Error 'OS error
13
Error 'OS error
14
Error 'Scsi error
15
Error 'Scsi error
16
Error 'OS error
17
Error 'OS error
18
Error 'OS error
19
Error 'OS error - 20 Error 'OS error 21 Error 'Scsi error 22 Error 'Scsi error 23 Error 'Scsi error 24 Error 'Scsi error 25 Error 'Scsi error 26 Error 'Scsi error 27 Error 'Scsi error 28 Error 'OS error
29
Error 'OS error
30
Error 'OS error
31
32
Error 'OS error
33
Error 'OS error
34
Error 'OS error
35
Error 'Scsi error
36
Error OS error
37
Error 'OS error
38
Error '03 error
39
Error 'OS error
40
Error 'OS error
STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo
at offset '808581120' at offset '808581120'
STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808581120'
Error 'Scsi error - MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808777728'
STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo' at offset '808777728' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo at offset '808777728' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo' at offset '808777728'
MEDIUM ERROR: L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '808845312' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRomo' at offset '808845312' STATUS DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808845312' STATUS DEVICE DATA ERROR' occurred while reading '\Device\CdRom0' at offset '808845312' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808845312' STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '808845312'
#12 Post by Woodstock » Wed Aug 27, 2025 4:37 pm
The errors posted are consistent with a drive trying to go faster than there is power available to go. How is this drive powered?
YouAcheDee
#13 Post by YouAcheDee » Wed Aug 27, 2025 5:10 pm
Interesting, I am using an LG BU40N Slim internal laptop drive which is connected via the default sata port on my Dell E6430S.
