Autoripping
Trunkybum
Autoripping
#1 Post by Trunkybum » Sun Mar 24, 2024 12:12 pm
Is there any way to autorip 4ks? I tried this in a vm: https://github.com/Poisonite/MakeMKV-Auto-Rip Triage said it was a virus
Re: Autoripping
#2 Post by Woodstock » Sun Mar 24, 2024 3:02 pm
From the description on the page you linked to, the type of disk wouldn't matter. Although, 4K disks are more likely to have issues with keys when new, so automatic ripping may be a problem with fresh disks.
Whether you trust it after that warning is up to you; No one here has any control over that page's contents. Personally, I check virustotal.com when assessing a program's virus status, and even MakeMKV will trigger warnings for new versions with some antivirus vendors. Submitting the download to those vendors results in them amending their findings. You might do that.
poisonite
Re: Autoripping
#3 Post by poisonite » Sat Aug 16, 2025 7:30 pm
I know this is a bit old, but I figured I'd reach out quickly.
Sorry that you were having an issue with my automation script. I just rewrote it from the ground up, if you're still looking for a solution for this, feel free to give the new version a try as it has a lot more features/flexibility.
https://github.com/Poisonite/MakeMKV-Auto-Rip#readme
Oh I also added a docker version and fixed a bunch of issues running it on Linux & macOS.
