AACS v82 dump_HTB0211
This is a machine translation of Japanese, so there may be some inaccuracies. I apologize.
You said to submit a dump file, but I attached the [~.tgz] file generated by MakeMKV and sent it to svq@makemkv.com.
Is it correct that you then uploaded the same file to this forum?
If I'm not mistaken, I would appreciate it if you could help.
At the moment, it seems that it doesn't play in VLC either.
Please let me know if there are any mistakes.
Thank you in advance.
Re: AACS v82 dump_HTB0211
Emailing the dump file to svq@makemkv.com is the correct thing to do. It will be processed and eventually made available as a hashed key.
There is a separate process called the Public KeyDB. If you make the dump file available for download on the internet somewhere and post a link, they can add a key to the keyDB.
MakeMKV can use the built-in hashed key mechanism and it can also use the Public KeyDB if you set it up to do so.
Public KeyDB Disc SubmissionsGoogle Translate wrote:ダンプファイルをsvq@makemkv.comにメールで送信するのが正しい方法です。ダンプファイルは処理され、最終的にハッシュキーとして利用可能になります。
公開鍵データベースと呼ばれる別のプロセスがあります。ダンプファイルをインターネット上のどこかにダウンロードできるようにし、リンクを投稿すれば、鍵データベースに鍵を追加できます。
MakeMKVは組み込みのハッシュキーメカニズムを使用できますが、設定すれば公開鍵データベースも使用できます。
Danpufairu o svq@ makemkv. Komu ni mēru de sōshin suru no ga tadashī hōhōdesu. Danpufairu wa shori sa re, saishūtekini hasshukī to shite riyō kanō ni narimasu. Kōkaiken dētabēsu to yoba reru betsu no purosesu ga arimasu. Danpufairu o intānetto-jō no doko ka ni daunrōdo dekiru yō ni shi, rinku o tōkō sureba, kagi dētabēsu ni kagi o tsuika dekimasu. MakeMKV wa kumikomi no hasshukīmekanizumu o shiyō dekimasuga, settei sureba kōkaiken dētabēsu mo shiyō dekimasu.
Thank you for your reply, dcoke22!
It's really helpful that you even included a Japanese translation.
First of all,
I've completed that.
Next, you provided a link to a detailed explanation of the [Public KeyDB] method in [Public KeyDB Disc Submissions], so I read that.
If I'm not misreading it,
>Pioneer drives are not supported for public key database use.
Unfortunately, my own drive is
Manufacturer: PIONEER
Product Name: BD-RW BDR-209M
so I thought this method wouldn't work.
So I'll wait for a response from the MakeMKV team.
Finally.
However, it's possible that the nuance of what I'm saying is completely different when translated using Google Translate, resulting in a very rude statement... I apologize if that's the case.
Thank you so much again for replying and teaching me so much!
First of all,
Finally.
I looked closely at my post and realized the attachment wasn't uploaded...
I'm sorry.
I tried to upload the dump file again, but
I got the message "Sorry, the board attachment quota has been reached."
I couldn't upload it.
I got an error saying the board attachment limit had been reached, but is this an error caused by a mistake on my part or some other error resulting from repeated postings and mistakes, or are there currently restrictions on uploads?
In this case, am I correct in thinking I can just upload it somewhere and post a link to it?
I would appreciate it if someone could explain.
I'm sorry.
Yes, you will have to upload the file to a different host and post the link here.
Dumps from some Pioneer drives may still work. Yours may be ok. You can't attach the dump here. You should upload it to another host such as google drive, one drive, mediafire etc and post the download link here.suna_ch wrote: Sat Aug 16, 2025 10:37 pm I looked closely at my post and realized the attachment wasn't uploaded...
I'm sorry.
Dear Toad King and Marty McNuts,
Thank you for your reply.
I tried uploading it to Google Drive after receiving advice to upload it to another location and then linking to it.
I think it should be shareable.
Here's the link:
https://drive.google.com/drive/folders ... rive_link
Thank you all for your help.
Here's the link:
It looks like the disc has been added to the KeyDB now. To use it with MakeMKV you can use either SamuriHL's tool if you are on Windows, or follow keydb_helper's guide otherwise.suna_ch wrote: Sun Aug 17, 2025 2:02 am Dear Toad King and Marty McNuts,
Here's the link:
Thank you for your reply, Toad King.
Thank you again for letting me know that KeyDB has been added.
You also provided a link explaining the steps from there, which was very helpful.
We're currently in the process of reading it. (It has been successfully recognized.)
Thank you very much to everyone who helped out.
I may need your help again in the future. I hope you'll help me out again then.
Well then, I'll be off.
