PIONEER BDR-209 change the Firmware ?
Re: PIONEER BDR-209 change the Firmware ?
Post by Coopervid » Wed Aug 06, 2025 9:15 pm
bitslayer wrote: Wed Aug 06, 2025 4:43 pm I am thinking about getting a pioneer BDR-209-DBK is drives firmware libre drive capable? coopervid can you please pm me. Thank you
No need to PM. Get a drive if you still can and post your Makemkv info. Hopefully it has a firmware before 12 / 2022. Otherwise you have to wait until Mike has a fix for newer firmware. No ETA for that.
doobleshaft
Post by doobleshaft » Wed Aug 06, 2025 9:43 pm
I have one of these on stock firmware 1.34 and have been looking for options.
Can't currently get MakeMKV to work despite downloading and installing from official links (v1.18.1) as it keeps saying:
This application version is too old. Please download the latest version at HTTP://www.makemkv.com/ or enter a registration key to continue using the current version.
Now I can't remember installing a previous version, but I was going to share the info from the drive and not sure how to do it. I can try with Linux later this week, as I dual boot with Ubuntu, or I can run another distro just for this.
I have other drives I can try but this is the one I was hoping to use.
Post by Coopervid » Wed Aug 06, 2025 10:02 pm
doobleshaft wrote: Wed Aug 06, 2025 9:43 pm I have one of these on stock firmware 1.34 and have been looking for options.
Off topic.
bebiprivat
Post by bebiprivat » Thu Aug 14, 2025 2:33 pm
Yet another one in need of an UHD friendly firmware for his Pioneer BDR-209D ;-)
Here 's the drive information from MakeMKV:
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-209D
Revision: 1.30
Serienummer:
Firmware-Datum: 2014-12-05
Markierungen der Bus-Verschlüsselung: 13
Drive platform: RS8600
Firmware version: 1.30/ID61
Thanks a lot in advance!
Post by Billycar11 » Thu Aug 14, 2025 7:34 pm
bebiprivat wrote: Thu Aug 14, 2025 2:33 pm Yet another one in need of an UHD friendly firmware for his Pioneer BDR-209D ;-)
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.30
Serienummer:
Sure email me that drive info see below
Blackmist08
Post by Blackmist08 » Fri Aug 15, 2025 7:22 pm
Hello Coopervid,
I am also interested in flashing my BDR-209 to be UHD friendly. Would you be able to help me? Thank you.
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.31
Serial number: [REDACTED]
Firmware date: 2015-05-25
Highest AACS version: 81
Firmware version: 1.31
Post by Coopervid » Sat Aug 16, 2025 5:03 pm
Blackmist08 wrote: Fri Aug 15, 2025 7:22 pm Hello Coopervid,
OS device name: H:
Revision: 1.31
PM sent.
mohaba
Post by mohaba » Sat Sep 06, 2025 9:30 am
I also have a 2014 era drive that I have updated at some point with the 2018 era firmware. Works great for normal HD BDs, but if I can get it crossflashed to do UHD BDs, that would be great.
OS device name: L:
Product: BD-RW BDR-209D
Revision: 1.51
Serial number:
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 68
Firmware version: 1.51/ID61
Post by Coopervid » Sat Sep 06, 2025 5:29 pm
mohaba wrote: Sat Sep 06, 2025 9:30 am I also have a 2014 era drive that I have updated at some point with the 2018 era firmware. Works great for normal HD BDs, but if I can get it crossflashed to do UHD BDs, that would be great.
OS device name: L:
Revision: 1.51
Serial number:
PM sent.
mh2702
Post by mh2702 » Sat Sep 06, 2025 6:48 pm
I have the following drive. Can it be upgraded to read 4K/Ultra HD Blu-Ray discs? If so, how can I do that?
Is there a difference between changing the drive firmware and reflashing? If so, what is the difference?
Thanks in advance.
OS device name: E:
Revision: 1.33
Serial number:
Firmware date: 2015-12-09
Highest AACS version: 72
Firmware version: 1.33
Post by Coopervid » Sat Sep 06, 2025 7:15 pm
mh2702 wrote: Sat Sep 06, 2025 6:48 pm I have the following drive. Can it be upgraded to read 4K/Ultra HD Blu-Ray discs? If so, how can I do that?
Thanks in advance.
OS device name: E:
Revision: 1.33
Serial number:
No difference. PM sent.
mh2702
Post by mh2702 » Sun Sep 07, 2025 4:26 am
Coopervid wrote: No difference. PM sent.
Thanks for your help!
StarLord
Post by StarLord » Sun Sep 07, 2025 8:23 pm
Hi Coopervid,
I have the same drive as well. Could you PM me as well please?
OS device name: /dev/sr1
Product: BD-RW BDR-S09
Revision: 1.10
Serial number:
Firmware date: 2013-10-15
Highest AACS version: 82
Firmware version: 1.10/ID43
Post by Coopervid » Mon Sep 08, 2025 9:01 am
StarLord wrote: Sun Sep 07, 2025 8:23 pm Hi Coopervid,
Revision: 1.10
Serial number:
PM sent.
graffitiMSX
Post by graffitiMSX » Fri Sep 12, 2025 9:39 pm
Hello, I have a Pioneer BDR-209MBK drive. I'm looking for help to make it UHD friendly with LibreDrive.
OS device name: E:
Current profile: BD-R SRM
Revision: 1.54
Serial number:
Firmware date: 2022-05-31
Firmware version: ID04
Thank you.
