LibreDrive for Pioneer drives
markginter31
#1561 Post by markginter31 » Fri Aug 15, 2025 11:21 am
Hi -- I have the following. I tried to follow the advice I could find, and got an older Pioneer drive with firmware from 2019. I assume it's flashable. Just need the tools to do it. Finding the tools is what I'm not entirely clear on.
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: AEDL033085WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 66
Drive platform: RS8F00
Firmware version: 1.00/ID61
#1562 Post by Billycar11 » Fri Aug 15, 2025 11:35 am
markginter31 wrote: Fri Aug 15, 2025 11:21 am Hi -- I have the following. I tried to follow the advice I could find, and got an older Pioneer drive with firmware from 2019. I assume it's flashable. Just need the tools to do it. Finding the tools is what I'm not entirely clear on.
Revision: 1.00
Sure email me that info
See below
BOXMI
#1563 Post by BOXMI » Fri Aug 15, 2025 9:10 pm
My PIONEER XS07TUHD is not on the list.
Libredrive is possible but not enabled.
Can you help me?
#1564 Post by MartyMcNuts » Fri Aug 15, 2025 11:51 pm
BOXMI wrote: Fri Aug 15, 2025 9:10 pm My PIONEER XS07TUHD is not on the list.
Can you help me?
Post your MakeMKV drive info & libredrive info sections.
Genovipers
#1565 Post by Genovipers » Sat Aug 16, 2025 3:31 am
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DHDL1XXXXXXX
Firmware date: 2020-07-21
Highest AACS version: 19
Firmware version: ID76
#1566 Post by Billycar11 » Sat Aug 16, 2025 5:04 am
Genovipers wrote: Sat Aug 16, 2025 3:31 am Drive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
yes that drive can be flashed email me for a kit
see below for email
d-n-c
#1567 Post by d-n-c » Sat Aug 16, 2025 2:36 pm
Hi there,
I stumbled across this thread today. Is there hope for my hard drive again?
Product: BD-RW BDR-XD07
Revision: 1.06
Serial number: TLDL005047WL
Firmware date: 2024-10-09
Drive platform: Pioneer RS8D30
Firmware version: GENE
Looking forward to your reply.
zhwghl
#1568 Post by zhwghl » Sat Aug 16, 2025 4:17 pm
Product: BD-RW BDR-XD06U
Revision: 1.00
Serial number: QDDL000516JP
Firmware date: 2017-02-24
Highest AACS version: 72
Drive platform: Pioneer RS8B30
Firmware version: ID69
Disc Information
Label: ONWARD
Timestamp: 2020-03-20 19:24:45
Protection: AACS2.0/C v72
Data capacity: 59.29 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
I cannot rip using my BD-RW BDR-XD06U. It was said that it works with the firmware 1.11. Should I upgrade the firmware to 1.11?
When I try to rip it says
Backup failed
Please let me know what should I do
log
MakeMKV v1.18.1 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XD06U 1.00 QDDL000516JPd" opened in OS access mode.
Backing up disc into folder "/Users/harry/Movies/backup/ONWARD"
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/98D03CFC'
Saved AACS dump file as /Users/harry/Library/MakeMKV/MKB20_v72_ONWARD_4D8D.tgz
Backup failed
#1569 Post by Billycar11 » Sat Aug 16, 2025 7:29 pm
zhwghl wrote: Sat Aug 16, 2025 4:17 pm Manufacturer: PIONEER
Revision: 1.00
Disc Information
Label: ONWARD
Number of layers: 2
Backup failed
log
Backup failed
Email me that drive info see below for email
#1570 Post by MartyMcNuts » Sun Aug 17, 2025 12:39 am
d-n-c wrote: Sat Aug 16, 2025 2:36 pm Hi there,
Revision: 1.06
No. Firmware is post 11/2022. You will have to wait for future support.
mrobby
#1571 Post by mrobby » Mon Aug 18, 2025 7:32 am
I have the following Logitec BR drive (seems to be Pioneer inside):
Product: BD-RW BDR-TD05
Revision: 1.00
Serial number: MCDLxxxxxxWL
Firmware date: 2012-07-23
Highest AACS version: 70
Drive platform: Pioneer RS8211
I tried flashing it for LibreDrive, but failed:
Mac-mini MacOS % ./sdftool -l
Found 1 drives(s)
DEBUG: code=00000000 src=|;#LqoJ6PV#w!yqdM,8vQ0]dc:29395149
00: /IOBDServices/4C69ADD1
  PIONEER_BD-RW___BDR-TD05_1.00_MCDL117115WL
Mac-mini MacOS % ./makemkvcon f -d /IOBDServices/4C69ADD1 -f sdf.bin rawflash main -i /Users/me/Downloads/All\ You\ Need\ Firmware\ Pack\ \(MartyMcNuts\)/Slim\ External\ Drives/DE_LG_BU40N_1.03_MK.bin
[b]Unknown command
Command produced error code 0xffffffff[/b]
What am I doing wrong? TIA !
#1572 Post by MartyMcNuts » Mon Aug 18, 2025 8:02 am
mrobby wrote: Mon Aug 18, 2025 7:32 am Hi,
Revision: 1.00
Found 1 drives(s)
[b]Unknown command
1. Pioneer drives cannot be flashed using MakeMKV's SDFtool. The Pioneer flashing tool is not publicly available.
2. Even if you can get LibreDrive enabled, it will not be able to read UHD discs as it is too old an incompatible.
mrobby
#1573 Post by mrobby » Mon Aug 18, 2025 8:12 am
MartyMcNuts wrote: Mon Aug 18, 2025 8:02 am 1. Pioneer drives cannot be flashed using MakeMKV's SDFtool. The Pioneer flashing tool is not publicly available.
Got it.
If possible, I'd be content to flash this into a regular, non-UHD LibreDrive BR drive. :D
Otherwise, I guess it's a spare DVD reader.
d-n-c
#1574 Post by d-n-c » Mon Aug 18, 2025 3:56 pm
MartyMcNuts wrote: Sun Aug 17, 2025 12:39 am
Revision: 1.06
Thank you, I will be waiting :-)
bigrippa4k
#1575 Post by bigrippa4k » Mon Aug 18, 2025 7:15 pm
Regarding the BDR-207's (specifically 207-DBK) what is the 'drive platform'? I found this model on marketplace for $20 and I'm considering taking the gamble but it sounds like most likely it will not be supported?
