LibreDrive for Pioneer drives
markginter31
Hi -- I have the following. I tried to follow the advice I could find, and got an older Pioneer drive with firmware from 2019. I assume it's flashable. Just need the tools to do it. Finding the tools is what I'm not entirely clear on.
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: AEDL033085WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 66
Drive platform: RS8F00
Firmware version: 1.00/ID61
Revision: 1.00
Sure email me that infomarkginter31 wrote: Fri Aug 15, 2025 11:21 am Hi -- I have the following. I tried to follow the advice I could find, and got an older Pioneer drive with firmware from 2019. I assume it's flashable. Just need the tools to do it. Finding the tools is what I'm not entirely clear on.
Revision: 1.00
See below
BOXMI
My PIONEER XS07TUHD is not on the list.
Libredrive is possible but not enabled.
Can you help me?
Can you help me?
Post your MakeMKV drive info & libredrive info sections.BOXMI wrote: Fri Aug 15, 2025 9:10 pm My PIONEER XS07TUHD is not on the list.
Can you help me?
Genovipers
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DHDL1XXXXXXX
Firmware date: 2020-07-21
Highest AACS version: 19
Firmware version: ID76
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
yes that drive can be flashed email me for a kitGenovipers wrote: Sat Aug 16, 2025 3:31 am Drive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
see below for email
d-n-c
Hi there,
I stumbled across this thread today. Is there hope for my hard drive again?
Product: BD-RW BDR-XD07
Revision: 1.06
Serial number: TLDL005047WL
Firmware date: 2024-10-09
Drive platform: Pioneer RS8D30
Firmware version: GENE
Looking forward to your reply.
Revision: 1.06
zhwghl
Product: BD-RW BDR-XD06U
Revision: 1.00
Serial number: QDDL000516JP
Firmware date: 2017-02-24
Highest AACS version: 72
Drive platform: Pioneer RS8B30
Firmware version: ID69
Disc Information
Label: ONWARD
Timestamp: 2020-03-20 19:24:45
Protection: AACS2.0/C v72
Data capacity: 59.29 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
I cannot rip using my BD-RW BDR-XD06U. It was said that it works with the firmware 1.11. Should I upgrade the firmware to 1.11?
When I try to rip it says
Backup failed
Please let me know what should I do
log
MakeMKV v1.18.1 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XD06U 1.00 QDDL000516JPd" opened in OS access mode.
Backing up disc into folder "/Users/harry/Movies/backup/ONWARD"
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/98D03CFC'
Saved AACS dump file as /Users/harry/Library/MakeMKV/MKB20_v72_ONWARD_4D8D.tgz
Backup failed
Revision: 1.00
Disc Information
Label: ONWARD
Number of layers: 2
Backup failed
log
Backup failed
Email me that drive info see below for emailzhwghl wrote: Sat Aug 16, 2025 4:17 pm Manufacturer: PIONEER
Revision: 1.00
Disc Information
Label: ONWARD
Number of layers: 2
Backup failed
log
Backup failed
No. Firmware is post 11/2022. You will have to wait for future support.d-n-c wrote: Sat Aug 16, 2025 2:36 pm Hi there,
Revision: 1.06
mrobby
I have the following Logitec BR drive (seems to be Pioneer inside):
I tried flashing it for LibreDrive, but failed:
What am I doing wrong? TIA !
Product: BD-RW BDR-TD05
Revision: 1.00
Serial number: MCDLxxxxxxWL
Firmware date: 2012-07-23
Highest AACS version: 70
Drive platform: Pioneer RS8211
Firmware version: GENECode: Select all
Mac-mini MacOS % ./sdftool -l
Found 1 drives(s)
DEBUG: code=00000000 src=|;#LqoJ6PV#w!yqdM,8vQ0]dc:29395149
00: /IOBDServices/4C69ADD1
PIONEER_BD-RW___BDR-TD05_1.00_MCDL117115WL
Mac-mini MacOS % ./makemkvcon f -d /IOBDServices/4C69ADD1 -f sdf.bin rawflash main -i /Users/me/Downloads/All\ You\ Need\ Firmware\ Pack\ \(MartyMcNuts\)/Slim\ External\ Drives/DE_LG_BU40N_1.03_MK.bin
[b]Unknown command
Command produced error code 0xffffffff[/b]-
1. Pioneer drives cannot be flashed using MakeMKV's SDFtool. The Pioneer flashing tool is not publicly available.mrobby wrote: Mon Aug 18, 2025 7:32 am Hi,
I tried flashing it for LibreDrive, but failed:Code: Select all
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-TD05 Revision: 1.00 Serial number: MCDLxxxxxxWL Firmware date: 2012-07-23 Bus encryption flags: 1B Highest AACS version: 70 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8211 Firmware version: GENE
What am I doing wrong? TIA !Code: Select all
Mac-mini MacOS % ./sdftool -l Found 1 drives(s) DEBUG: code=00000000 src=|;#LqoJ6PV#w!yqdM,8vQ0]dc:29395149 DEBUG: code=00000000 src=|;#LqoJ6PV#w!yqdM,8vQ0]dc:29395149 00: /IOBDServices/4C69ADD1 PIONEER_BD-RW___BDR-TD05_1.00_MCDL117115WL Mac-mini MacOS % ./makemkvcon f -d /IOBDServices/4C69ADD1 -f sdf.bin rawflash main -i /Users/me/Downloads/All\ You\ Need\ Firmware\ Pack\ \(MartyMcNuts\)/Slim\ External\ Drives/DE_LG_BU40N_1.03_MK.bin [b]Unknown command Command produced error code 0xffffffff[/b]
2. Even if you can get LibreDrive enabled, it will not be able to read UHD discs as it is too old an incompatible.
mrobby
Got it.MartyMcNuts wrote: Mon Aug 18, 2025 8:02 am 1. Pioneer drives cannot be flashed using MakeMKV's SDFtool. The Pioneer flashing tool is not publicly available.
If possible, I'd be content to flash this into a regular, non-UHD LibreDrive BR drive.
Otherwise, I guess it's a spare DVD reader.
d-n-c
Thank you, I will be waitingMartyMcNuts wrote: Sun Aug 17, 2025 12:39 amNo. Firmware is post 11/2022. You will have to wait for future support.d-n-c wrote: Sat Aug 16, 2025 2:36 pm Hi there,
Revision: 1.06
bigrippa4k
Regarding the BDR-207's (specifically 207-DBK) what is the 'drive platform'? I found this model on marketplace for $20 and I'm considering taking the gamble but it sounds like most likely it will not be supported?
