[SOLVED] Flashing Buffalo BRXL-PTV6U3-BK/N (2020 model from Japan)
mrobby
#1 Post by mrobby » Fri Aug 15, 2025 3:28 pm
Using this drive on a mac mini m4, I was unable to read BluRay discs using MakeMKV.
Here are the drive specs: https://www.buffalo.jp/product/detail/b ... -bk_n.html
Since MakeMKV reported that LibreDrive was possible but not enabled, I tried flashing it.
$ /Applications/MakeMKV.app/Contents/MacOS/sdftool -l
Found 1 drives(s)
DEBUG: code=00000000 src=|;#LqoJ6PV#w!yqdM,8vQ0]dc:29395149
00: /IOBDServices/86AE8945
  BUFFALO_Optical_Drive_1.03_211810241934_MO5KCS83746
$ ./makemkvcon f -d /IOBDServices/86AE8945 -f sdf.bin rawflash enc -i /Users/me/Downloads/All\ You\ Need\ Firmware\ Pack\ \(MartyMcNuts\)/Slim\ External\ Drives/DE_Buffalo_BRUHD-PU3_BN12-MK.bin
However, this doesn't seem to have worked. I can mount a BluRay disc and the volume name appears in the Finder, but MakeMKV just gets stuck and reports a series of Scsi Errors 'NOT READY'.
Is the drive bricked? If not, what is the correct firmware I should use?
TIA !
Re: Flashing Buffalo BRXL-PTV6U3-BK/N (2020 model from Japan)
#2 Post by Billycar11 » Fri Aug 15, 2025 5:33 pm
Power issue?
Try a high powered USB hub 35+watts
mrobby
#3 Post by mrobby » Fri Aug 15, 2025 5:39 pm
Billycar11 wrote: Fri Aug 15, 2025 5:33 pm Power issue?
I was wondering about that. Forgot to mention there is a LED on the rear top of the drive that flashes green slowly during mount, and then flashes red.
Is that an indication there isn't enough power?
EDIT: I tried a separate hub connected to a single USB-C port and now the LED on the rear doesn't flash but I get a series of errors like this:
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE BUFFALO Optical Drive 1.03 MO5KCS83746' at offset '1245184'.
#4 Post by Billycar11 » Fri Aug 15, 2025 10:06 pm
mrobby wrote: Fri Aug 15, 2025 5:39 pm
yes red means not enough power
mrobby
#5 Post by mrobby » Fri Aug 15, 2025 10:47 pm
Thanks. I tried two different powered hubs, but I still get "invalid destination port" errors from MakeMKV.
I think I must have eff'd up the flashing step.
For this drive, is the DE_Buffalo_BRUHD-PU3_BN12-MK.bin firmware the correct one to use?
#6 Post by MartyMcNuts » Fri Aug 15, 2025 11:47 pm
Whatever hub used must have it's own AC power source, not be powered from USB port and as Billy said, be at least 35W.
#7 Post by MartyMcNuts » Fri Aug 15, 2025 11:48 pm
mrobby wrote: Fri Aug 15, 2025 10:47 pm Thanks. I tried two different powered hubs, but I still get "invalid destination port" errors from MakeMKV.
That firmware should work but most people just go with BU40N 1.03-MK.
mrobby
#8 Post by mrobby » Sat Aug 16, 2025 12:04 am
Thanks. I'll try again with a different powered hub and report back.
Is there some functional difference (i.e., higher speed) between BR drives need two USB cables vs. drives that only need one?
#9 Post by MartyMcNuts » Sat Aug 16, 2025 1:05 am
mrobby wrote: Sat Aug 16, 2025 12:04 am Thanks. I'll try again with a different powered hub and report back.
No functional differences. I think it's just that some enclosures/PCB in the enclosure require more power than others.
mrobby
#10 Post by mrobby » Sun Aug 17, 2025 1:32 am
You guys were right: it was a power issue. Tried connecting both drive cables to a 36W powered hub and now it works/rips as expected.
I also changed the firmware as suggested:
./makemkvcon f -d BUFFALO_Optical_Drive_1.03_211810241934_MO5KCS83746 -f sdf.bin rawflash enc -i /Users/me/Downloads/All\ You\ Need\ Firmware\ Pack\ \(MartyMcNuts\)/Slim\ External\ Drives/DE_LG_BU40N_1.03_MK.bin
Thanks again for all your help ! :D
