LibreDrive for Pioneer drives
markginter31
Post by markginter31 »
Hi -- I have the following. I tried to follow the advice I could find, and got an older Pioneer drive with firmware from 2019. I assume it's flashable. Just need the tools to do it. Finding the tools is what I'm not entirely clear on.
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: AEDL033085WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 66
Drive platform: RS8F00
Firmware version: 1.00/ID61
markginter31 wrote:
Fri Aug 15, 2025 11:21 am
Revision: 1.00
Sure email me that info
See below
BOXMI
Post by BOXMI »
My PIONEER XS07TUHD is not on the list.
Libredrive is possible but not enabled.
Can you help me?
BOXMI wrote:
Fri Aug 15, 2025 9:10 pm
Can you help me?
Post your MakeMKV drive info & libredrive info sections.
Genovipers
Post by Genovipers »
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DHDL1XXXXXXX
Firmware date: 2020-07-21
Highest AACS version: 19
Firmware version: ID76
Genovipers wrote:
Sat Aug 16, 2025 3:31 am
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
yes that drive can be flashed email me for a kit
see below for email
d-n-c
Post by d-n-c »
Hi there,
I stumbled across this thread today. Is there hope for my hard drive again?
Product: BD-RW BDR-XD07
Revision: 1.06
Serial number: TLDL005047WL
Firmware date: 2024-10-09
Drive platform: Pioneer RS8D30
Firmware version: GENE
Looking forward to your reply.
zhwghl
Post by zhwghl »
Product: BD-RW BDR-XD06U
Revision: 1.00
Serial number: QDDL000516JP
Firmware date: 2017-02-24
Highest AACS version: 72
Drive platform: Pioneer RS8B30
Firmware version: ID69
Disc Information
Label: ONWARD
Timestamp: 2020-03-20 19:24:45
Protection: AACS2.0/C v72
Data capacity: 59.29 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
I cannot rip using my BD-RW BDR-XD06U. It was said that it works with the firmware 1.11. Should I upgrade the firmware to 1.11?
When I try to rip it says
Backup failed
Please let me know what should I do
log
MakeMKV v1.18.1 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XD06U 1.00 QDDL000516JPd" opened in OS access mode.
Backing up disc into folder "/Users/harry/Movies/backup/ONWARD"
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:/IOBDServices/98D03CFC'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/98D03CFC'
Saved AACS dump file as /Users/harry/Library/MakeMKV/MKB20_v72_ONWARD_4D8D.tgz
Backup failed
zhwghl wrote:
Sat Aug 16, 2025 4:17 pm
Revision: 1.00
Disc Information
Label: ONWARD
Number of layers: 2
Backup failed
log
Backup failed
Email me that drive info see below for email
d-n-c wrote:
Sat Aug 16, 2025 2:36 pm
Hi there,
Revision: 1.06
No. Firmware is post 11/2022. You will have to wait for future support.
mrobby
Post by mrobby »
I have the following Logitec BR drive (seems to be Pioneer inside):
Product: BD-RW BDR-TD05
Revision: 1.00
Serial number: MCDLxxxxxxWL
Firmware date: 2012-07-23
Highest AACS version: 70
Drive platform: Pioneer RS8211
I tried flashing it for LibreDrive, but failed:
Mac-mini MacOS % ./sdftool -l
Found 1 drives(s)
DEBUG: code=00000000 src=|;#LqoJ6PV#w!yqdM,8vQ0]dc:29395149
00: /IOBDServices/4C69ADD1
  PIONEER_BD-RW___BDR-TD05_1.00_MCDL117115WL
Mac-mini MacOS % ./makemkvcon f -d /IOBDServices/4C69ADD1 -f sdf.bin rawflash main -i /Users/me/Downloads/All\ You\ Need\ Firmware\ Pack\ \(MartyMcNuts\)/Slim\ External\ Drives/DE_LG_BU40N_1.03_MK.bin
[b]Unknown command
Command produced error code 0xffffffff[/b]
What am I doing wrong? TIA !
mrobby wrote:
Mon Aug 18, 2025 7:32 am
Revision: 1.00
Found 1 drives(s)
[b]Unknown command
1. Pioneer drives cannot be flashed using MakeMKV's SDFtool. The Pioneer flashing tool is not publicly available.
2. Even if you can get LibreDrive enabled, it will not be able to read UHD discs as it is too old an incompatible.
mrobby
Post by mrobby »
MartyMcNuts wrote:
Mon Aug 18, 2025 8:02 am
Got it.
If possible, I'd be content to flash this into a regular, non-UHD LibreDrive BR drive. :D
Otherwise, I guess it's a spare DVD reader.
d-n-c
Post by d-n-c »
MartyMcNuts wrote:
Sun Aug 17, 2025 12:39 am
Hi there,
Revision: 1.06
Thank you, I will be waiting :-)
bigrippa4k
Post by bigrippa4k »
Regarding the BDR-207's (specifically 207-DBK) what is the 'drive platform'? I found this model on marketplace for $20 and I'm considering taking the gamble but it sounds like most likely it will not be supported?
