DVD backup failed
hangman on benzene
DVD backup failed
#1 Post by hangman on benzene » Wed May 15, 2024 4:52 pm
When trying to backup some DVDs, this specific one always fails.
Here is the drive and disc information:
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL1NAH82833
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
Disc Information
Label: LOTR_TWO_TOWERS_SEE_D4
Timestamp: 2003-09-19 18:08:05
Protection: CSS/CPPM
Data capacity: 7.72 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
I already tried cleaning it.
I googled the debug codes and found a few posts with somewhat similar errors, but the solutions from these did not work for me f.e. changing DVD opening mode.
Here is the log:
MakeMKV v1.17.6 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Name/MakeMKV_log.txt
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Backing up disc into folder "D:/Movies/backup/LOTR_TWO_TOWERS_SEE_D4.iso"
DEBUG: Code 118095996 at 0`Ya?1$!|%$JJIlO4"I>U-z:29394183
DEBUG: Code 0 at 0`Ya?1$!|%$JJIlO4"I>U-z:121263590
DEBUG: Code 1790 at _y<{y.H`KydrY`/TJ{+d:213133250
DEBUG: Code 67174400 at _y<{y.H`KydrY`/TJ{+d:121265062
DEBUG: Code 1 at _y<{y.H`KydrY`/TJ{+d:29394689
DEBUG: Code 3221225649 at LKu,[_<phG675tlGM#:cb<I:29394919
DEBUG: Code 3221225649 at 0`Ya?1$!|%$JJIlO4"I>U-z:213130145
DEBUG: Code 3221225480 at LKu,[_<phG675tlGM#:cb<I:121262509
DEBUG: Code 3221225480 at 0`Ya?1$!|%$JJIlO4"I>U-z:29394183
DEBUG: Code 0 at /u`0WKB|YXK!?|:29397104
DEBUG: Code 0 at ps]e,OePl_hCE6(^~9XG:121266097
Backup failed
All other LotR appendices DVDs do not have this problem.
VLC can play the DVD from the drive.
Ripping the videos from the DVD works.
Can someone help me here?
Telecart
Re: DVD backup failed
#2 Post by Telecart » Fri Jul 12, 2024 4:32 am
Same issue. DVD plays, MakeMKV can rip the title from the DVD to .mkv, but when trying to backup the DVD to an ISO, consistent error no matter the protection method.
info:
OS device name: /dev/rdisk8
Manufacturer: PIONEER
Product: BD-RW BDR-S13JX
Revision: 1.03
Serial number: DDDL930070UC
Firmware date: 2022-07-26
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID72
Disc Information
Label: LOGICAL VOLUME IDENTIFIER
Timestamp: 2001-01-01 23:58:37
Data capacity: 2.44 Gb
Disc type: DVD-R
Disc size: 120mm
Number of layers: 1 (PTP)
debug log
Debug log started at Fri Jul 12 04:17:15 2024 , written by MakeMKV v1.17.7 darwin(arm64-release)
001005:0000 MakeMKV v1.17.7 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/me/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.1.2/(SecureTransport) LibreSSL/3.3.6/1.51.0 (x86_64-apple-darwin22.0) , proxy server not set.
002010:0000 Optical drive "BD-RE PIONEER BD-RW  BDR-S13JX 1.03 DDDL930070UCd" opened in OS access mode.
SDF  v098: PIONEER_BD-RW__BDR-S13JX_1.03_DDDL930070UC
001011:0000 Using LibreDrive mode (v01.0 id=E9BA8ECC61EF)
005072:0000 Backing up disc into folder "file:///Users/me/Movies/backup/LOGICAL VOLUME IDENTIFIER.iso"
DEBUG: Code 1 at [ld+(z2V>R|Hq9vV/:121263199
Launching /Applications/MakeMKV.app/Contents/MacOS/mmgplsrv
DEBUG: Code 0 at }mT2_e%/aa^D)js,KHrb:29396460
001003:0020 DEBUG: Code 0 at WsC|cmJ80Jei;}:4-cz%:121266097
005069:0080 Backup failed
005080:0204 Backup failed.
Thomasg003
#3 Post by Thomasg003 » Tue Mar 11, 2025 11:32 pm
Did you find a solution I’m having the same problem
monoWench
#4 Post by monoWench » Fri Aug 15, 2025 9:38 am
Both of my copies of this disc have the same problem. The copy from my original 2004 Australian TTT EE DVD Box Set and the copy included in my 2011 Australian LOTR Trilogy EE Bluray Boxset.
I gave up trying to use MakeMKV to backup the disc and just used DVD Decrypter to create an iso
