Post
by dcoke22 » Thu Aug 14, 2025 3:06 pm
melchioe wrote: Thu Aug 14, 2025 1:52 pm
Thanks for the tip - I did find the log file (in the lowest level of my user directory). I'll be sending the resultant log file to
support@makemkv.com. I was hoping to find hints directly in the log file, but it's not set up for that. Thanks again!
Have you power cycled your optical drive? Have you tried gently cleaning your discs? Have you tried cleaning the optics of your optical drive?
