1.18.1-Win too old?
oms-muc
1.18.1-Win too old?
Post by oms-muc » Thu Aug 14, 2025 10:41 am
Hi.
I'm getting the above error when I start 1.18.1 on Windows.
Anyone else affected as well?
THX
Oliver
Re: 1.18.1-Win too old?
Post by Woodstock » Thu Aug 14, 2025 2:59 pm
Usually means you're using an expired key - the one included IN the file expired last month, and you need to use the one in this message to update it.
When you have a permanent key, you shouldn't see this again. Back before MakeMKV did dynamic updates for things like keys, changing the program out periodically was more important.
Smithcraft
Post by Smithcraft » Sat Aug 16, 2025 2:18 am
The problem is that you can't do anything because when you accept the error message is closes the application.
I did an uninstall to see if would wipe the existing install, but after reinstalling it I still can't run it cuz it's too old.
You have to do the date trick, then grab a key from the key thread, then you can update the key and restart it to get it to work.
SC
