Loaded 4 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00003.svq
DEBUG: Code 0 at TGb_/?./CmJ(|~Ie:213136608
DEBUG: Code 0 at TGb_/?./CmJ(|~Ie:29397633
DEBUG: Code 0 at TGb_/?./CmJ(|~Ie:29403199
Failed to process BD+ code using generic SVQ from builtin/00003.svq
Processing BD+ code using generic SVQ from builtin/00002.svq
BD+ code processed but no FUTs were obtained, errors may follow
Title #00007.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00100.mpls was added as title #0
Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00201.m2ts was added as title #1
File 00202.m2ts was added as title #2
Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00203.m2ts was added as title #3
Title #00002.m2ts has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/nas01
DBG ASSERT: Vz8>t+,"sB0,1rPuHelPo@1H{vX@CMZ'b-MH5R,%'!v]xG~Cqa$2jE]mHS},Q{`*(AVi,+U(:Ow""6Vp at ]qX|z9=hnXm1uhP&~qBB:121264487
DEBUG: Code 1 at ]qX|z9=hnXm1uhP&~qBB:213134952
DEBUG: Code 0 at lZh;q~Z2z^@ wI091*cc&:213134216
DEBUG: Code 0 at !qK@>N/mRAHTW1?#@]=:213132031
Failed to save title 0 to file /Volumes/nas01/t00_Contagion.mkv
0 titles saved, 1 failed
Contagion will not rip ...
Re: Contagion will not rip ...
OneFastSkater
Well that was certainly weird. Well written FAQ, thanks for pointing it out to me.
This morning without doing anything (cleaning the disk, offering sacrifices to the God's) Contagion ripped.
setarip_old
That's because an updated SVQ was likely submitted and added to the database after your first attempt...This morning without doing anything (cleaning the disk, offering sacrifices to the God's) Contagion ripped.
NutFlush920
setarip_old
@nutflush920
Your success at an earlier date could be due to the fact that, as stated by "fengtao", asuthor of DVDFab ae etal, there were THREE different protection versions of "Contagion" released...
