King of Queens The Complete Series (Mill Creek)
kevinadams05
Post by kevinadams05 »
Has anyone ripped King of Queens The Complete Series (Mill Creek release) yet? I am trying to understand which episode is which, and all my normal techniques are failing me.
I normally try to compare the episode duration to dvdcompare.net, but the durations don't seem to match. The DiscDB lists every episode as 25 mins so that doesn't help either. I also don't see a playlist or play all option that I can use for reference.
Is there anything else I can try?
Re: King of Queens The Complete Series (Mill Creek)
I haven't ripped that series.
However, if you look at the credits in every episode you can probably reach a high degree of certainly by looking at the director and writers for each episode.
https://en.wikipedia.org/wiki/List_of_The_King_of_Queens_episodes#Season_1_(1998–99)
If you make a decrypted backup of the disc you can play an episode's .m2ts file right out of the backup.
kevinadams05
Thanks for the director and writer tip! I hadn't thought of that.
I did find this review online which lists the duration of each episode:
https://www.spookcentral.tk/tcp/2024/12 ... ray-review
That is helping, except on some discs there are multiple episodes with the same duration. In those cases, I have been going one by one to try to identify them based on the screen cap posted on TVDB. Using writer/director will probably be easier.
I'm building out an Excel sheet that maps each track to it's corresponding episode. I will post that when I am done, just in case it helps anyone in the future.
kevinadams05 wrote: Mon Feb 17, 2025 4:17 pm I'm building out an Excel sheet that maps each track to it's corresponding episode. I will post that when I am done, just in case it helps anyone in the future.
Hopefully your spreadsheet is mapping the segment map -> episode title.
kevinadams05
dcoke22 wrote: Tue Feb 18, 2025 5:10 am Hopefully your spreadsheet is mapping the segment map -> episode title.
It's a pretty detailed spreadsheet. I am mapping things this way:
Episode Name: Bun Dummy
Episode Number: S04E21
Disc Number (As appears on the physical disc): Season 4 Disc 2
File length: 21:18
MPLS file name: 00006.mpls
MakeMKV file name: title_t06
Plex Friendly File Name: The King of Queens S04E21
The MPLS file name will be useful but the MakeMKV file name generally won't be.
MakeMKV appends the "_t06" part, for example, to help ensure that every produced .mkv file ends up with a unique name. But it depends on how many titles MakeMKV sees to begin with.
By default, the minimum title length is 120 seconds (the Video tab of MakeMKV's preferences). Every title that is less than 120 seconds is ignored. If this setting is changed, it will increase or decrease the number of titles that MakeMKV sees. This implies that the title with _t06 appended when the minimum title length is 120 might end up with something different appended to it when the minimum title length is different.
The MPLS file name, however, will be consistent regardless of any settings like minimum title length. The segment map will also be consistent.
I should also mention, I often use the resources at DVDCompare.net when I'm ripping things.
https://dvdcompare.net/comparisons/film.php?fid=39353
In this case, it looks like they do not have data for the Mill Creek Entertainment version of that show on blu-ray.
In addition to posting your data here, it could be helpful to the wider community if you figured out to how post your data with them so it could be added to their listings.
redbeard719
Post by redbeard719 »
kevinadams05 wrote: Tue Feb 18, 2025 3:53 pm
File length: 21:18
Hi, I found your thread while searching for a cross reference between titles and episode listings for this series.
By chance did you ever complete your spreadsheet? I'd be very grateful if you wouldn't mind sharing it!
Thank you!
redbeard719
If anyone comes back across this thread and needs the info, I've listed it out below!
The King of Queens
Season 1
Disc1
t00 - s1e3
t01 - s1e2
t02 - s1e4
t03 - s1e5
t04 - s1e6
t05 - s1e7
t06 - s1e1
Disc 2
t00 - s1e11
t01 - s1e8
t02 - s1e9
t03 - s1e10
t04 - s1e12
t05 - s1e13
t06 - s1e14
t07 - s1e15
Disc 3
t00 - s1e21
t01 - s1e23
t02 - s1e24
t03 - s1e22
t04 - s1e16
t05 - s1e19
t06 - s1e20
t07 - s1e25
t08 - s1e17
t09 - s1e18
Season 2
Disc 1
t00 - s2e1
t01 - s2e5
t02 - s2e3
t03 - s2e4
t04 - s2e6
t05 - s2e7
t06 - s2e2
Disc 2
t00 - s2e10
t01 - s2e11
t02 - s2e12
t03 - s2e8
t04 - s2e13
t05 - s2e14
t06 - s2e15
t07 - s2e16
t08 - s2e9
Disc 3
t00 - s2e24
t01 - s2e25
t02 - s2e19
t03 - s2e20
t04 - s2e17
t05 - s2e18
t06 - s2e23
t07 - s2e21
t08 - s2e22
Season 3
Disc 1
t00 - s3e1
t01 - s3e2
t02 - s3e3
t03 - s3e4
t04 - s3e5
t05 - s3e6
t06 - s3e7
Disc 2
t00 - s3e12
t01 - s3e15
t02 - s3e16
t03 - s3e13
t04 - s3e14
t05 - s3e8
t06 - s3e9
t07 - s3e10
t08 - s3e11
Disc 3
t00 - s3e20
t01 - s3e21
t02 - s3e22
t03 - s3e23
t04 - s3e24
t05 - s3e25
t06 - s3e17
t07 - s3e18
t08 - s3e19
Season 4
Disc 1
t00 - s4e3
t01 - s4e5
t02 - s4e6
t03 - s4e7
t04 - s4e9
t05 - s4e10
t06 - s4e12
t07 - s4e4
t08 - s4e8
t09 - s4e11
t10 - s4e1
t11 - s4e2
Disc 2
t00 - s4e14
t01 - s4e16
t02 - s4e17
t03 - s4e18
t04 - s4e19
t05 - s4e20
t06 - s4e21
t07 - s4e23
t08 - s4e24
t09 - s4e25
t10 - s4e15
t11 - s4e22
t12 - s4e13
Season 5
Disc 1
t00 - s5e1
t01 - s5e2
t02 - s5e3
t03 - s5e5
t04 - s5e6
t05 - s5e7
t06 - s5e8
t07 - s5e9
t08 - s5e10
t09 - s5e11
t10 - s5e4
t11 - s5e12
Disc 2
t00 - s5e13
t01 - s5e14
t02 - s5e15
t03 - s5e17
t04 - s5e18
t05 - s5e19
t06 - s5e20
t07 - s5e21
t08 - s5e22
t09 - s5e24
t10 - s5e25
t11 - s5e16
t12 - s5e23
Season 6
Disc 1
t00 - s6e1
t01 - s6e2
t02 - s6e3
t03 - s6e4
t04 - s6e5
t05 - s6e6
t06 - s6e8
t07 - s6e12
t08 - s6e9
t09 - s6e10
t10 - s6e11
t11 - s6e7
Disc 2
t00 - s6e14
t01 - s6e15
t02 - s6e16
t03 - s6e17
t04 - s6e18
t05 - s6e19
t06 - s6e20
t07 - s6e21
t08 - s6e22
t09 - s6e23
t10 - s6e24
t11 - s6e13
Season 7
Disc 1
t00 - s7e1
t01 - s7e2
t02 - s7e4
t03 - s7e6
t04 - s7e7
t05 - s7e8
t06 - s7e9
t07 - s7e11
t08 - s7e5
t09 - s7e3
t10 - s7e10
Disc 2
t00 - s7e12
t01 - s7e13
t02 - s7e14
t03 - s7e15
t04 - s7e16
t05 - s7e17
t06 - s7e18
t07 - s7e19
t08 - s7e20
t09 - s7e21
t10 - s7e22
Season 8
Disc 1
t00 - s8e1
t01 - s8e11
t02 - s8e2
t03 - s8e4
t04 - s8e6
t05 - s8e7
t06 - s8e8
t07 - s8e9
t08 - s8e10
t09 - s8e3
t10 - s8e5
Disc 2
t00 - s8e12
t01 - s8e13
t02 - s8e14
t03 - s8e15
t04 - s8e16
t05 - s8e19
t06 - s8e20
t07 - s8e21
t08 - s8e22
t09 - s8e23
t10 - s8e18
t11 - s8e17
Season 9
Disc 1
t00 - s9e2
t01 - s9e4
t02 - s9e9
t03 - s9e10
t04 - s9e12
t05 - s9e11
t06 - s9e13
t07 - s9e7
t08 - s9e8
t09 - s9e1
t10 - s9e3
t11 - s9e5
t12 - s9e6
