Coopervid wrote: Wed Aug 13, 2025 1:18 pm
There is a beta key. Apply it an post your current info. I suspect that flashing hasn‘t worked with your special setup. You could have also checked with the flasher afterwards. But some people just don‘t follow the tutorial.
I DID follow the tutorial. No disc was inside and the tray was closed. Not too hard. The shown model type in the flashing tool was also different after the process so it obviously worked. This is the current Data from MakeMKV:
OS device name: /dev/rdisk21
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: CIDL505512WL
Firmware date: 2020-06-15
Highest AACS version: 48
Drive platform: RS8A10
Firmware version: 1.14
Ok this is weird. Now that I have found the public key and re-activated MakeMKV it works. But only with MakeMKV. I Already bought AnyMP4 Blu Ray Ripper as I didn't believe, MakeMKV would be usable one day. I really hope, it will be maintained and subsequent beta keys will be released.
Coopervid wrote: Wed Aug 13, 2025 3:17 pm
Fine! I only use AnyDvd and XReveal besides Makemkv. That program you mention is not recommended if you ask me.
Alright, thank you for your help and advice!
You are very welcome! Next time ask what is recommended. You should now also be able to PM.
I bought the Verbatim 43889 today in Germany and got the following Pioneer Drive:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Drive platform: RS8511
strangely Makemkv didn't show the entry: Highest AACS version. Can i flash this drive to rip UHD Discs and can somebody help me with the firmware?
many thanks in advance
Airwax wrote: Wed Aug 13, 2025 8:36 pm
Revision: 1.14
Serial number: ...
looks like this is my final hope.
I bought the drive a week ago and am desperately trying to find the patch to enable the UHD feature.
I would be grateful for any help.
OS device name: H:
Revision: 1.14
Serial number: ........
Highest AACS version: 65
cookie02 wrote: Fri Aug 15, 2025 11:40 am
OS device name: H:
Revision: 1.14
OS device name: H:
Revision: 1.14
Rebirth3936 wrote: Wed Aug 20, 2025 11:24 am
Hi, bought used Verbatim 43891. Would it be possible to flash this drive? If it is, is there a guide on how to do it so?
