Pioneer BDR-UD03 UHD possibility
joshi21
Re: Pioneer BDR-UD03 UHD possibility
Post by joshi21 »
Coopervid wrote: Wed Aug 13, 2025 1:18 pm There is a beta key. Apply it an post your current info. I suspect that flashing hasn‘t worked with your special setup. You could have also checked with the flasher afterwards. But some people just don‘t follow the tutorial.
I DID follow the tutorial. No disc was inside and the tray was closed. Not too hard. The shown model type in the flashing tool was also different after the process so it obviously worked. This is the current Data from MakeMKV:
OS device name: /dev/rdisk21
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: CIDL505512WL
Firmware date: 2020-06-15
Highest AACS version: 48
Drive platform: RS8A10
Firmware version: 1.14
joshi21
Post by joshi21 »
Ok this is weird. Now that I have found the public key and re-activated MakeMKV it works. But only with MakeMKV. I Already bought AnyMP4 Blu Ray Ripper as I didn't believe, MakeMKV would be usable one day. I really hope, it will be maintained and subsequent beta keys will be released.
Fine! I only use AnyDvd and XReveal besides Makemkv. That program you mention is not recommended if you ask me.
joshi21
Post by joshi21 »
Coopervid wrote: Wed Aug 13, 2025 3:17 pm Fine! I only use AnyDvd and XReveal besides Makemkv. That program you mention is not recommended if you ask me.
Alright, thank you for your help and advice!
joshi21 wrote: Wed Aug 13, 2025 3:24 pm
You are very welcome! Next time ask what is recommended. You should now also be able to PM.
halcyonvault wrote: Wed Aug 13, 2025 2:52 pm Lmk if this drive is compatible. Thanks!
OS device name: E:
Product: BD-RW BDR-UD03
Revision: 1.00
Serial number:
Firmware date: 2013-08-09
Highest AACS version: 81
Drive platform: RS8510
Firmware version: 1.00/ID19
Yes email me that info see below
Airwax
Post by Airwax »
I bought the Verbatim 43889 today in Germany and got the following Pioneer Drive:
Revision: 1.14
Serial number: ...
Drive platform: RS8511
strangely Makemkv didn't show the entry: Highest AACS version. Can i flash this drive to rip UHD Discs and can somebody help me with the firmware?
many thanks in advance
Airwax wrote: Wed Aug 13, 2025 8:36 pm I bought the Verbatim 43889 today in Germany and got the following Pioneer Drive:
Revision: 1.14
Serial number: ...
PM sent.
cookie02
Post by cookie02 »
looks like this is my final hope.
I bought the drive a week ago and am desperately trying to find the patch to enable the UHD feature.
I would be grateful for any help.
OS device name: H:
Revision: 1.14
Serial number: ........
Highest AACS version: 65
Kind regards
cookie02 wrote: Fri Aug 15, 2025 11:40 am looks like this is my final hope.
OS device name: H:
Revision: 1.14
Kind regards
PM sent.
cookie02
Post by cookie02 »
Coopervid wrote: Fri Aug 15, 2025 3:15 pm
OS device name: H:
Revision: 1.14
Kind regards
PM sent.
Works like a charm.
Thank you very much!
Rebirth3936
Post by Rebirth3936 »
Hi, bought used Verbatim 43891. Would it be possible to flash this drive? If it is, is there a guide on how to do it so?
Revision: 1.05
Serial number:
Firmware date: 2015-11-24
Highest AACS version: 60
Firmware version: 1.05
Rebirth3936 wrote: Wed Aug 20, 2025 11:24 am Hi, bought used Verbatim 43891. Would it be possible to flash this drive? If it is, is there a guide on how to do it so?
Revision: 1.05
Serial number:
Sure email me that drive info see below
krakken
Post by krakken »
Having the same issue I guess. Can anyone PM me the solution?
Revision: 1.14
Serial number:
Highest AACS version: 47
krakken wrote: Thu Aug 21, 2025 8:43 am Having the same issue I guess. Can anyone PM me the solution?
Revision: 1.14
Serial number:
just email it to me see below for email
