ISO problem
promisq
ISO problem
#1 Post by promisq » Mon Aug 03, 2009 4:50 pm
First of all a big thanks to Mike for his great effort in making this software!
I do run into issues when converting an .iso to MKV. It doesn't matter if I mount the ISO and select the .bdmv file or just select the .iso MakeMKV always crashes when I start converting. I tried doing this with different iso files on a networkshare and on the system harddisk.
Please find my log:
003010:000000:0000 Using direct disc access mode
003310:000000:0000 AACS directory not present, assuming unencrypted disc
003313:000000:0000 File 00000.mpls was added as title #0
003020:000000:0000 Title #00001.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory /Volumes/Data2/Movies
001012:000000:0020 FAILURE: Code 4139778951 at !\Q$ioj54vu$c;dt4~|:121262578
001012:000000:0020 FAILURE: Code 210 at !\Q$ioj54vu$c;dt4~|:121262417
001012:000000:0020 FAILURE: Code 0 at nk]HJF-;xyMw2gjuB$qHu:121264211
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 0 to file /Volumes/Data2/Movies/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
Application exited at Mon Aug 3 16:49:16 2009
cyrdog
Re: ISO problem
#2 Post by cyrdog » Tue Oct 27, 2009 2:51 pm
I am having the same issue. MakeMKV crashes with a fatal error with every ISO that I've tried. I tried 4 different ISOs, and all crashed at different points. I tried v1.4.7 and v1.4.8 on both OS X 10.5.8 and 10.6.1. All encounter issues with ISOs.
cyrdog
Re: ISO problem
#3 Post by cyrdog » Tue Oct 27, 2009 3:06 pm
Here are 2 examples of my log files trying to convert 2 different ISO files:
Debug log started at Tue Oct 27 14:57:31 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/Mark/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at %$K'7k/|wNr!5t\jn#?F9B<s@CM:121264878
005014:000000:0000 Saving 1 titles into directory /Users/Mark/Desktop
001012:000000:0020 FAILURE: Code 2147483647 at cEAA|'u{_hN9%;Hx7So:121261474
Debug log started at Tue Oct 27 15:00:16 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
005001:000000:0308 File /Users/Mark/Desktop/title00.mkv already exist. Do you want to overwrite it?
001012:000000:0020 FAILURE: Code 3235046876 at ;48]N:"$RtN]o-is"8}:121262578
001012:000000:0020 FAILURE: Code 208 at ;48]N:"$RtN]o-is"8}:121262417
001012:000000:0020 FAILURE: Code 0 at Ki[$9xEvae-@2&CECQJW_:121264211
kungktd
Re: ISO problem
#4 Post by kungktd » Tue Nov 03, 2009 12:22 pm
Same problem here. I have not been able to convert a single iso yet. :(
Log:
Debug log started at Tue Nov  3 11:53:38 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
001013:000000:0000 Debug logging enabled, log will be saved as /Users/qaz/MakeMKV_log.txt
003036:000000:0000 Title #0 was added (18 cell(s), 1:14:56)
003036:000000:0000 Title #1 was added (18 cell(s), 1:15:03)
003036:000000:0000 Title #2 was added (18 cell(s), 1:15:04)
003020:000000:0000 Title #3 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #4 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #5 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #6 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #7 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #8 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #9 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #10 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #11 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #12 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #13 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003014:000000:0000 Title #14 with special attributes was skipped
003014:000000:0000 Title #15 with special attributes was skipped
005014:000000:0000 Saving 1 titles into directory /Users/qaz/Desktop
001012:000000:0020 FAILURE: Code 384 at Ki[$9xEvae-@2&CECQJW_:29394965
001012:000000:0020 FAILURE: Code 480000000 at cEAA|'u{_hN9%;Hx7So:121261474
001012:000000:0020 FAILURE: Code 672 at Ki[$9xEvae-@2&CECQJW_:29394965
Image of when the error occurred:
(program are misspelled)
Re: ISO problem
#5 Post by mike admin » Wed Nov 04, 2009 10:53 am
what software was used to rip or create these? All 3 logs show different failures but they all lie in timecode area - it looks like discs are badly authored, but it is very strange. The second disc shows problem due to subtitle track, so deselecting all subtitles may help.
