If you bought it last month and got a registration code - is it working currently?
All topics related to functioning of this forum or MakeMKV website
boe_d
Post by boe_d »
I'm just curious if your software still works. I have no problem paying for the software if it still works even when the freeware doesn't. Just curious.
Thanks.
Blyth
Re: If you bought it last month and got a registration code - is it working currently?
Post by Blyth »
You will have a problem as you can't buy it at the moment. If you haven't bought it then carry on using the beta key and backing the month to July on the computer you are using.
The software still works. I purchased a permanent key years ago and the software still works as it always has.
As Blyth mentioned, the ability to purchase a permanent key is currently broken. Hopefully it'll be fixed soon. The current beta key is expired and hopefully a new one will be posted soon. Until then, you can find instructions on the forum for how to set your computer's clock back to make the old beta key work.
Glittering-Wing-8059
Post by Glittering-Wing-8059 »
I can confirm my permanent key is working fine.
I think I must have been one of the last few to get my key before all this started. I purchased about 9:45 GMT on 1 Aug and got my key bet email in about 5 minutes.
I only discovered the software I’d say about a month or so ago and knew nothing about the beta key until I tried to use it on 1 Aug and got the ‘version too old’ message. I’m impatient and tend to hyper fixate so when it stopped working I just decided to buy the permanent key so I didn’t have to wait, which seems to have saved me a whole load of frustration on this occasion!
boe_d
Post by boe_d »
Thanks everyone.
Blkkalel
Post by Blkkalel »
Cant seem to purchase permanent key, how do I find beta key? I am new here forgive me for noob question
Blkkalel wrote: Wed Aug 13, 2025 1:17 pm Cant seem to purchase permanent key, how do I find beta key? I am new here forgive me for noob question
https://forum.makemkv.com/forum/viewtopic.php?f=5&t=1053
