MakeMKV Expired Key Work Around (MakeMKV-Loader)
Chaos6616
Re: MakeMKV Expired Key Work Around (MakeMKV-Loader)
Strange, I have to keep my system time in July in order to decrypt anything
flojo
So you're implying that the program executes. Try putting keydb.cfg in $HOME/.MakeMKV. Anyhow, good luck.Chaos6616 wrote: Tue Aug 12, 2025 5:12 am Strange, I have to keep my system time in July in order to decrypt anything
RossRoy79
What I found personally is that I needed to make sure the time stays "wrong" and won't update again while MakeMKV is running / reading disc / decrypting.Chaos6616 wrote: Tue Aug 12, 2025 5:12 am Strange, I have to keep my system time in July in order to decrypt anything
Other than that - it works great !
Of course, now that the new key is out - this is moot .. until September at least
Alekhine
I just saw that MIKE has returned and finally entered the BETA code valid until September.
En Ajedrez pierde el que comete el penúltimo error
In chess, the player who makes the penultimate mistake loses.
ufococoa
I installed the MakeMKV-Loader yesterday or the day before, and now my PC is swarming with viruses. Thank you, I guess I'll spend the night doing a complete reinstall of my system.
Terron1
Weird, it doesnt require an install. Wonder what you downloaded lolufococoa wrote: Wed Aug 13, 2025 5:14 pm I installed the MakeMKV-Loader yesterday or the day before, and now my PC is swarming with viruses. Thank you, I guess I'll spend the night doing a complete reinstall of my system.
smol_birb
What happened?ufococoa wrote: Wed Aug 13, 2025 5:14 pm I installed the MakeMKV-Loader yesterday or the day before, and now my PC is swarming with viruses. Thank you, I guess I'll spend the night doing a complete reinstall of my system.
ufococoa
You're right, I did not install anything, just downloaded it from your Google Drive and ran it. Anyways, my F-Secure scanner said it was a virus. I ran the scan a few more times, and let it clean the folder MakeMKV-Loader was in, and now it seems everything's OK. But I dare not run the loader again.Terron1 wrote: Wed Aug 13, 2025 5:49 pmWeird, it doesnt require an install. Wonder what you downloaded lolufococoa wrote: Wed Aug 13, 2025 5:14 pm I installed the MakeMKV-Loader yesterday or the day before, and now my PC is swarming with viruses. Thank you, I guess I'll spend the night doing a complete reinstall of my system.
Windows Security barked about it, but I suspect it was because it was unsigned, rather than anything malignant? Just buy a key & avoid this sort of madness.ufococoa wrote: Wed Aug 13, 2025 6:37 pmYou're right, I did not install anything, just downloaded it from your Google Drive and ran it. Anyways, my F-Secure scanner said it was a virus. I ran the scan a few more times, and let it clean the folder MakeMKV-Loader was in, and now it seems everything's OK. But I dare not run the loader again.Terron1 wrote: Wed Aug 13, 2025 5:49 pmWeird, it doesnt require an install. Wonder what you downloaded lolufococoa wrote: Wed Aug 13, 2025 5:14 pm I installed the MakeMKV-Loader yesterday or the day before, and now my PC is swarming with viruses. Thank you, I guess I'll spend the night doing a complete reinstall of my system.
ufococoa
You, too, are right: I really should buy a key.d00zah wrote: Wed Aug 13, 2025 7:01 pmWindows Security barked about it, but I suspect it was because it was unsigned, rather than anything malignant? Just buy a key & avoid this sort of madness.ufococoa wrote: Wed Aug 13, 2025 6:37 pmYou're right, I did not install anything, just downloaded it from your Google Drive and ran it. Anyways, my F-Secure scanner said it was a virus. I ran the scan a few more times, and let it clean the folder MakeMKV-Loader was in, and now it seems everything's OK. But I dare not run the loader again.Terron1 wrote: Wed Aug 13, 2025 5:49 pm
Weird, it doesnt require an install. Wonder what you downloaded lol![]()
Terron1
After having to make the loader just for my personal use, I have also decided to buy a key hahaha! I'm now the proud owner of a permanent keyufococoa wrote: Thu Aug 14, 2025 7:06 amYou, too, are right: I really should buy a key.d00zah wrote: Wed Aug 13, 2025 7:01 pmWindows Security barked about it, but I suspect it was because it was unsigned, rather than anything malignant? Just buy a key & avoid this sort of madness.ufococoa wrote: Wed Aug 13, 2025 6:37 pm
You're right, I did not install anything, just downloaded it from your Google Drive and ran it. Anyways, my F-Secure scanner said it was a virus. I ran the scan a few more times, and let it clean the folder MakeMKV-Loader was in, and now it seems everything's OK. But I dare not run the loader again.![]()
