Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
#736 Post by Coopervid » Wed Aug 06, 2025 7:35 pm
joshi21 wrote: Wed Aug 06, 2025 5:55 pm
Coopervid wrote: Wed Aug 06, 2025 4:41 am Use a Windows PC or VMware. You seem to be on Linux and that is the issue.
No I use a M1 Max MacBook Pro running Windows 11 with Parallels.
Try to get help from a friend with a Windows PC. Did you make sure no disc in drive and tray is closed? It usually works with Parallels.
joshi21
#737 Post by joshi21 » Wed Aug 06, 2025 8:19 pm
Coopervid wrote: Wed Aug 06, 2025 7:35 pm
Yes, the tray was empty and closed. I'll try VMware or connecting it to my Synology NAS with forwadding the usb port to a VM on the NAS.
#738 Post by Coopervid » Wed Aug 06, 2025 8:22 pm
joshi21 wrote: Wed Aug 06, 2025 8:19 pm
Making it complicated doesn't help. VMWare or pure Windows will work.
joshi21
#739 Post by joshi21 » Thu Aug 07, 2025 3:16 pm
Coopervid wrote: Wed Aug 06, 2025 8:22 pm
In my case it helped. The weird way using VM on my NAS was the only way it worked for me. Thank you very much!
Nanjo99
#740 Post by Nanjo99 » Sat Aug 09, 2025 8:39 pm
I want it too please. Can you send me a Pm?
#741 Post by Coopervid » Mon Aug 11, 2025 9:37 am
Nanjo99 wrote: Sat Aug 09, 2025 8:39 pm I want it too please. Can you send me a Pm?
You need to post your Makemkv info.
Nanjo99
#742 Post by Nanjo99 » Mon Aug 11, 2025 2:57 pm
Coopervid wrote: Mon Aug 11, 2025 9:37 am
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: AGDL417716WL
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8511
Firmware version: 1.14
#743 Post by Coopervid » Mon Aug 11, 2025 7:05 pm
Nanjo99 wrote: Mon Aug 11, 2025 2:57 pm
Revision: 1.14
PM sent. Be warned: Some VMs don't work under Linux or MacOS. Use VMWare or a Windows PC.
mymake
#744 Post by mymake » Tue Aug 12, 2025 5:58 pm
Possible with this one? Currently shows "no disc inserted" if a 4K disc is in it. With a BD in it, here's the info:
OS device name: /dev/sr1
Revision: 1.11
Serial number: ***********
Firmware date: 2018-11-28
Highest AACS version: 77
Firmware version: 1.11
#745 Post by Coopervid » Wed Aug 13, 2025 9:14 am
mymake wrote: Tue Aug 12, 2025 5:58 pm Possible with this one? Currently shows "no disc inserted" if a 4K disc is in it. With a BD in it, here's the info:
Revision: 1.11
PM sent.
joshi21
#746 Post by joshi21 » Wed Aug 13, 2025 12:23 pm
Today I got my first two 4K Blu Ray Movies to try it. Unfortunately it doesn't work. I cross flashed my drive following your tutorial and flashing process seemed to work fine. But 4K Movies can't be played or ripped. Do you know another solution?
#747 Post by Coopervid » Wed Aug 13, 2025 12:45 pm
joshi21 wrote: Wed Aug 13, 2025 12:23 pm
Post your Makemkv info.
joshi21
#748 Post by joshi21 » Wed Aug 13, 2025 1:00 pm
Coopervid wrote: Wed Aug 13, 2025 12:45 pm
This is the data from MakeMKV BEFORE I cross flashed the drive. As MakeMKV is dead now I cant use it to get current information after flashing:
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer: ------------
Firmware-Datum: 2018-11-28
Highest AACS version: 62
#749 Post by Coopervid » Wed Aug 13, 2025 1:18 pm
There is a beta key. Apply it an post your current info. I suspect that flashing hasn‘t worked with your special setup. You could have also checked with the flasher afterwards. But some people just don‘t follow the tutorial.
halcyonvault
#750 Post by halcyonvault » Wed Aug 13, 2025 2:52 pm
Lmk if this drive is compatible. Thanks!
OS device name: E:
Revision: 1.00
Serial number:
Firmware date: 2013-08-09
Highest AACS version: 81
Drive platform: RS8510
Firmware version: 1.00/ID19
