I'm having the exact same problem with the exact same drive.
OS device name: Y:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLZO83A3328
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 76
I've tried tried cross flashing with the ASUS-BW-16D1HT-3.10-WM01601-211901041014 and ASUS-BW-16D1HT-3.10-WM01601-211901041014hk firmware using the Asus flasher and have gotten errors in both cases.
Latest firmware for Asus bw-16d1ht
Re: Latest firmware for Asus bw-16d1ht
use sdf tool or cmd with enc
asus flasher is only for 3.10 and lowervrs2010 wrote: Wed Aug 13, 2025 8:40 am I'm having the exact same problem with the exact same drive.
OS device name: Y:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
I tried doing it with the SDFtool Flasher and it worked perfectly. Case solved.
will there be a patched 3.11 for the Asus bw-16d1ht?
It's possible but really who cares it's not needed to do UHD or to downgrade
