Latest firmware for Asus bw-16d1ht
vrs2010
Re: Latest firmware for Asus bw-16d1ht
Post by vrs2010 »
I'm having the exact same problem with the exact same drive.
OS device name: Y:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLZO83A3328
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 76
I've tried tried cross flashing with the ASUS-BW-16D1HT-3.10-WM01601-211901041014 and ASUS-BW-16D1HT-3.10-WM01601-211901041014hk firmware using the Asus flasher and have gotten errors in both cases.
use sdf tool or cmd with enc
vrs2010 wrote: Wed Aug 13, 2025 8:40 am I'm having the exact same problem with the exact same drive.
OS device name: Y:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
asus flasher is only for 3.10 and lower
vrs2010
Post by vrs2010 »
I tried doing it with the SDFtool Flasher and it worked perfectly. Case solved. :)
Mordaur
Post by Mordaur »
will there be a patched 3.11 for the Asus bw-16d1ht?
Mordaur wrote: Fri Sep 05, 2025 6:09 pm will there be a patched 3.11 for the Asus bw-16d1ht?
It's possible but really who cares it's not needed to do UHD or to downgrade
