Yep, BU40N 1.03-MK.Morbinus wrote: Tue Aug 12, 2025 6:44 pm Hello. I have this Blueray drive laying around and I want to know if it is possible to flash it, since I saw a firmware available for BU40N. Would that work with my drive?
Here is the MakeMKV information:Code: Select all
Drive Information OS device name: E: Current profile: BD-ROM Manufacturer: HL-DT-ST Product: BD-RE BU40N Revision: 1.05 Serial number: <REDACTED> Firmware date: 2124-04-23 13:47 Bus encryption flags: 17 Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959
jakenitefire
Hello, can someone tell me if my drive is possible to flash?
The label on the drive says "MFD May 2017"
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.34
Serial number: censored
Firmware date: 2016-04-25
Bus encryption flags: 13
Highest AACS version: 78
Drive platform: RS8600
Firmware version: 1.34/ID60
No disc insertedRe: Ultimate UHD Drives Flashing Guide Updated 2025
I was looking into getting an internal 9.5mm drive and came across this listing, but the price seemed too good to be true, so I did not go any further with it. Not sure how to determine if it's truly a fake store or not, but I'm very skeptical of it: https://www.multione.net/bu40n-ultra-sl ... 780909.htm
As far as I can tell there is no need to flash the drive, since everything says "Yes" and the status says "Enabled". It should work out of the box.jakenitefire wrote: Wed Aug 13, 2025 8:38 am Hello, can someone tell me if my drive is possible to flash?
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-209M Revision: 1.34 Serial number: censored Firmware date: 2016-04-25 Bus encryption flags: 13 Highest AACS version: 78 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.34/ID60 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
I may be totally wrong since I am also new to this. Just give it a try with a UHD Blueray
That's differently fake and a scam sitemmortal03 wrote: Wed Aug 13, 2025 12:09 pm I was looking into getting an internal 9.5mm drive and came across this listing, but the price seemed too good to be true, so I did not go any further with it. Not sure how to determine if it's truly a fake store or not, but I'm very skeptical of it:
jakenitefire
Morbinus wrote: Wed Aug 13, 2025 1:33 pmAs far as I can tell there is no need to flash the drive, since everything says "Yes" and the status says "Enabled". It should work out of the box.jakenitefire wrote: Wed Aug 13, 2025 8:38 am Hello, can someone tell me if my drive is possible to flash?
I tried, but it doesn't read UHD Blu-rays.
What does the output of MakeMKV look like? Does it mention a missing volume key? If so you need to download these separatelyjakenitefire wrote: Wed Aug 13, 2025 9:43 pmMorbinus wrote: Wed Aug 13, 2025 1:33 pmAs far as I can tell there is no need to flash the drive, since everything says "Yes" and the status says "Enabled". It should work out of the box.jakenitefire wrote: Wed Aug 13, 2025 8:38 am Hello, can someone tell me if my drive is possible to flash?
LibreDrive does not equal UHD readaiblity! Is the 209M an actual UHD drive?? If not, it needs to be cross-flashed to a UHD model.jakenitefire wrote: Wed Aug 13, 2025 9:43 pmMorbinus wrote: Wed Aug 13, 2025 1:33 pmAs far as I can tell there is no need to flash the drive, since everything says "Yes" and the status says "Enabled". It should work out of the box.jakenitefire wrote: Wed Aug 13, 2025 8:38 am Hello, can someone tell me if my drive is possible to flash?
jakenitefire
MartyMcNuts wrote: Thu Aug 14, 2025 4:56 amLibreDrive does not equal UHD readaiblity! Is the 209M an actual UHD drive?? If not, it needs to be cross-flashed to a UHD model.jakenitefire wrote: Wed Aug 13, 2025 9:43 pmMorbinus wrote: Wed Aug 13, 2025 1:33 pm
It's not a UHD drive. I would like to know if flashing to a UHD model is even possible with my drive.
@Morbinus
It doesn't recognize that a disc is inserted.
PM is coming.jakenitefire wrote: Wed Aug 13, 2025 8:38 am Hello, can someone tell me if my drive is possible to flash?
ruhomallyaj
Hey guys,
I have a verbatim ultra hd 4k drive, and tried using DE_LG_BU40N_1.00.bin / This failed the same error where it ask to put a BD in and check it can still read without errors, it can but hesitent incase I missing something I used the above but maybe I am going v wrong here?
Post your MakeMKV drive info/libredrive info sections.ruhomallyaj wrote: Fri Aug 15, 2025 10:05 pm Hey guys,
Did you flash BU40N 1.03-MK first? This should be done first to remove the original firmware encryption. You can then flash to BU40N 1.00 afterwards.
Hi all.
I just got a ASUS BW-16D1HT 3.11 and accidentally flashed it to BC-12D2HT 3.11.
It seems to work ok for makemkv, but now it's stuck on that firmware.
What can I do to flash it to "ASUS-BW-16D1HT-3.10-WM01601-211901041014" which is what is what it should be.
I have Apollo 13 on 4K... got as a gift, and in the process of ripping now.
It comes up as a BD-ROM drive, not that I would burn a 4k disc,
but is the drive now unable to burn any kind of disc?
Use the recovery function and follow the promptsrockridge wrote: Mon Aug 18, 2025 12:25 pm Hi all.
