Can my drive be flashed?
OS device name: /dev/rdisk3
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: DHDL005779UC
Firmware date: 2022-12-27
Highest AACS version: 77
Drive platform: Pioneer RS9331
Firmware version: ID05
Thanks in advance
Enabling Libredrive on BDR-XD08U
Re: Enabling Libredrive on BDR-XD08U
No, not currently as the firmware is too new. Must be pre Dec 2022. You will have to wait for the newer drives to be supported.nntpjunkie wrote: Wed Aug 13, 2025 3:44 am Can my drive be flashed?
Revision: 1.02
Thanks in advance
nntpjunkie
Thanks mate, I just ordered one of your drives, so I should be good nowNo, not currently as the firmware is too new. Must be pre Dec 2022. You will have to wait for the newer drives to be supported.
