Morbinus wrote: Tue Aug 12, 2025 6:44 pm Hello. I have this Blueray drive laying around and I want to know if it is possible to flash it, since I saw a firmware available for BU40N. Would that work with my drive?
Here is the MakeMKV information:
OS device name: E:
Product: BD-RE BU40N
Revision: 1.05
Serial number: <REDACTED>
Highest AACS version: 81
Yep, BU40N 1.03-MK.
jakenitefire
Post by jakenitefire »
Hello, can someone tell me if my drive is possible to flash?
The label on the drive says "MFD May 2017"
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.34
Serial number: censored
Firmware date: 2016-04-25
Bus encryption flags: 13
Highest AACS version: 78
Drive platform: RS8600
Firmware version: 1.34/ID60
mmortal03
Post by mmortal03 »
I was looking into getting an internal 9.5mm drive and came across this listing, but the price seemed too good to be true, so I did not go any further with it. Not sure how to determine if it's truly a fake store or not, but I'm very skeptical of it: https://www.multione.net/bu40n-ultra-sl ... 780909.htm
Morbinus
Post by Morbinus »
jakenitefire wrote: Wed Aug 13, 2025 8:38 am Hello, can someone tell me if my drive is possible to flash?
OS device name: F:
Revision: 1.34
As far as I can tell there is no need to flash the drive, since everything says "Yes" and the status says "Enabled". It should work out of the box.
I may be totally wrong since I am also new to this. Just give it a try with a UHD Blueray
mmortal03 wrote: Wed Aug 13, 2025 12:09 pm I was looking into getting an internal 9.5mm drive and came across this listing, but the price seemed too good to be true, so I did not go any further with it. Not sure how to determine if it's truly a fake store or not, but I'm very skeptical of it:
That's differently fake and a scam site
jakenitefire
Morbinus wrote: Wed Aug 13, 2025 1:33 pm
OS device name: F:
Revision: 1.34
I tried, but it doesn't read UHD Blu-rays.
Morbinus
Post by Morbinus »
jakenitefire wrote: Wed Aug 13, 2025 9:43 pm
OS device name: F:
Revision: 1.34
What does the output of MakeMKV look like? Does it mention a missing volume key? If so you need to download these separately
OS device name: F:
Revision: 1.34
LibreDrive does not equal UHD readaiblity! Is the 209M an actual UHD drive?? If not, it needs to be cross-flashed to a UHD model.
jakenitefire
MartyMcNuts wrote: Thu Aug 14, 2025 4:56 am
It's not a UHD drive. I would like to know if flashing to a UHD model is even possible with my drive.
@Morbinus
It doesn't recognize that a disc is inserted.
OS device name: F:
Revision: 1.34
PM is coming.
ruhomallyaj
Post by ruhomallyaj »
Hey guys,
I have a verbatim ultra hd 4k drive, and tried using DE_LG_BU40N_1.00.bin / This failed the same error where it ask to put a BD in and check it can still read without errors, it can but hesitent incase I missing something I used the above but maybe I am going v wrong here?
ruhomallyaj wrote: Fri Aug 15, 2025 10:05 pm Hey guys,
Post your MakeMKV drive info/libredrive info sections.
Did you flash BU40N 1.03-MK first? This should be done first to remove the original firmware encryption. You can then flash to BU40N 1.00 afterwards.
rockridge
Post by rockridge »
Hi all.
I just got a ASUS BW-16D1HT 3.11 and accidentally flashed it to BC-12D2HT 3.11.
It seems to work ok for makemkv, but now it's stuck on that firmware.
What can I do to flash it to "ASUS-BW-16D1HT-3.10-WM01601-211901041014" which is what is what it should be.
rockridge
Post by rockridge »
I have Apollo 13 on 4K... got as a gift, and in the process of ripping now.
It comes up as a BD-ROM drive, not that I would burn a 4k disc,
but is the drive now unable to burn any kind of disc?
rockridge wrote: Mon Aug 18, 2025 12:25 pm Hi all.
Use the recovery function and follow the prompts
