beta keyy expired
sargentjeffery
beta keyy expired
can't use program because the key expired last month. please update the key thanks
Re: beta keyy expired
Old news, started earlier this weekend. Doesn't solve your immediate problem but read FAQ about BETA and PERMANENT keys. & maybe, read some related forum topics... there are many.sargentjeffery wrote: Wed Aug 06, 2025 9:13 pm can't use program because the key expired last month. please update the key thanks
hjason7812
Yeah does no good at all due to the program actually not working anymore not even with the time trick so hinestly this program is dead due to it being hosted in Russia
And yet, there are numerous reports to the contrary. Plenty of reading material if you are up to it.hjason7812 wrote: Tue Aug 12, 2025 5:19 pm Yeah does no good at all due to the program actually not working anymore not even with the time trick so hinestly this program is dead due to it being hosted in Russia
Rayotter
For Microsoft Users, I've been using "Any DVD" (downloadable by Microsoft Store) with the subscription which is $12 US for a year. It opens DVDs and Bluerays and converts them too; among other features. Hope this helps.
GmanEst72
Hi, take a look at some of the other feeds, it will tell you to put your system date back to say last month example 7th July. It's a work around that everyone else is doing for now including me.
Hope it helps
Hope it helps
smol_birb
No longer needed. The new beta key has just been published - valid until September.GmanEst72 wrote: Tue Aug 12, 2025 9:09 pm Hi, take a look at some of the other feeds, it will tell you to put your system date back to say last month example 7th July. It's a work around that everyone else is doing for now including me.
Hope it helps![]()
GmanEst72
There is still no permanent key though. So remember the workaround in case same thing happens end of September.
