Pioneer BDR-S13C-X manufactured in January 2023
Ludo91
Post by Ludo91 »
I found a brand new Pioneer BDR-S13C-X from a reseller on Aliexpress (all sold out on Asmcom unfortunately), but the manufacturing date is January 2023.
Is there a chance the F/W version can still be 1.03 ?
They sent me a picture of the label from the warehouse, but can't plug the drive to check the version.
Thanks in advance.
Re: Pioneer BDR-S13C-X manufactured in January 2023
Post your Makemkv info. If firmware is equal / newer than 12/2022 you have to wait for a fix by mike.
dont support the scalpers on ali express i will have pioneers end of September for much less than $520-$700 they are charging and they dont even guarantee the fw mine are guaranteed to have fw that works for UHD
i will have mostly xd08
Ludo91
Post by Ludo91 »
Thanks for your answer.
I didn't buy it, I was just "eventually considering" doing so, but wanted more information before.
I'll wait for yours. ;-)
cqecho
Post by cqecho »
I contacted with a Taobao seller for BDR-S13C-X, the date in the box is 2023/Jan, but seller confirmed the firmware version is 1.03 and show me the capture photo, so I order one and wait to prize draw, if louck is 1.03 will post the seller here.
cqecho
Post by cqecho »
Finally received Pioneer BDR-S13CX(MakeMKV show BDR-S13JX) drive and confirm the firmware 1.03 2022-7-26, I can use MakeMKV to rip UHD title no problem, here is the link.
https://drive.google.com/file/d/1NqZl58 ... sp=sharing
https://item.taobao.com/item.htm?id=730 ... ice=198000
tomatodory
Post by tomatodory »
Billycar11 wrote: Tue Aug 12, 2025 12:08 am dont support the scalpers on ali express i will have pioneers end of September for much less than $520-$700 they are charging and they dont even guarantee the fw mine are guaranteed to have fw that works for UHD
When MakeMKV starts supporting FW 1.04 and 1.05 for the BDR-S13U-X, do you have any of these drives sitting on a shelf with FW higher than 1.03 just waiting to be sold, or did you only take in ones with FW 1.03 and below and are now completely out of stock for the BDR-S13U-X?
tomatodory wrote: Sat Oct 25, 2025 10:51 am
I have a lot sitting in the shelf
But mostly xd08
Very few x13ux I think 1-2
tomatodory
Billycar11 wrote: Sat Oct 25, 2025 5:26 pm
But mostly xd08
I've already got a Verbatim 43888 with the Pioneer BDR-UD04 drive inside, so picking up the XD08 wouldn't make much sense for me. However, the X13U-X is basically just the S13U-X but in an external enclosure, so I'll wait until you open up shop again and hope I'm able to grab one, though I'm pretty sure the competition will be quite fierce when there's not that many of them left out there.
